Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: xtra speed cantilever system for trx-4
Old 04-15-2019, 12:36 AM   #1
Default xtra speed cantilever system for trx-4
Found this under new items at rcmart don't know if it was still posted here
Xtra Speed Cantilever Kit For Traxxas TRX-4
for Traxxas TRX-4 #XS-TX28086, ,(XS-TX28086) by Xtra Speed Cantilever Kit
magic_yeti is offline   Reply With Quote
Old 04-15-2019, 03:45 AM   #2
Default Re: xtra speed cantilever system for trx-4
Not sure i like how far away the mounting point on the chassis rail is. Look to me like it would bend the fixing bolt pretty easily...
neilus is offline   Reply With Quote
Old 04-15-2019, 08:47 AM   #3
With cantilever installed why haven't they nixed the old shock towers, should they not be redundant then.
That should make it possible to move things in 3 mm or so.
Maybe the body are held in place by those ( just go to prove for how long time i have not used regular body mounting options )
And that i don't own a TRX4
Peaker is offline   Reply With Quote
Old 04-15-2019, 09:13 AM   #4
they are only needed for the stock body posts, which i assume you won't use with a flatbed setup where this setup is normally used.
Old 04-15-2019, 05:18 PM   #5
Yeah i read that flatbed part on the listing at RC mart, but you sure as hell are not going to fit on a deep flat bed with those posts there.
If i was in this ballgame which i am not,,,,
Then i think i would be tempted to widen the frame rails in the back some how or make double frame rails, so i could get the shocks on the inside of the outer rail and maybe outboard the connection point for the lower push rod to the portal housing.
Seem to me its all very narrow
Old 04-17-2019, 07:04 PM   #6
I could see using this suspension if you were building a caged rear truggy. Otherwise I don't see the need for a cantilever setup.
Inspector86 is offline   Reply With Quote
xtra speed cantilever system for trx-4 - Similar Threads
Xtra Speed Ar60’s dpcardoza General Crawlers 26 11-06-2019 10:35 AM
Xtra Speed MG 5 door Frank211 Paint and Body 4 01-28-2019 08:12 AM
Xtra speed 334 wb Frank211 General Scale Talk 2 01-19-2018 12:16 PM
Xtra Speed Steering Fozzy73 Axial Wraith 13 08-22-2015 06:33 AM
xtra speed rc roughneck General Crawlers 6 04-06-2014 09:17 PM
