Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Performance of the Proline Jeep 324mm body
Old 04-23-2021, 02:48 AM   #1
Default Performance of the Proline Jeep 324mm body
I've picked up a Trx 4 Defender and all reports suggest this body is super tippy and top heavy. I'm trying to decide whether to drop it to 313mm and put a sport body on it or try a different 324mm body.
I like the idea of being able to quickly swap back the Defender body when I feel like it so the Proline Jeep body is an attractive option. It will also work out a lot cheaper than doing the conversion (£48 shell vs about £100 in parts to go sport...)
How is the performance of the Proline Jeep body? Does it get the COG down enough to fix some of the tippyness of the Defender?
My only real issue with the Jeep at the moment is I definitely prefer the flatbed look of the Sport body but I can't find anything in a 324mm wheelbase that has a flatbed.
Lostdotfish is offline   Reply With Quote
Old 04-23-2021, 08:03 AM   #2
Default Re: Performance of the Proline Jeep 324mm body
I think the Jeep body will definitely help lower the centre of gravity. A lot of the weight on the defender body is from the cage, so you could also try removing, but then you lose the look. A lot of folks have opted to add brass weights to the axles which really helps plant the weight down low.
To be perfectly honest, if all your are doing is moderate trail rides with the occasional moderate hill or rock climb you shouldn’t need to alter your truck to much. I put brass portal covers and a Bow House low centre of gravity tray on my defender and that works just fine the crawling I do.
rowntrp is offline   Reply With Quote
Old 04-23-2021, 11:01 AM   #3
This body? https://www.amainhobbies.com/proline...502-00/p730270
I had this exact body and it was a good improvement over the stock Bronco, so I can only imagine how much of a difference it would be compared to the Defender.
_________________
https://www.instagram.com/island_crawlaz/
79 F150 SCX10 ii
TRXWalker
ScaleLifeNewbie is offline   Reply With Quote
Performance of the Proline Jeep 324mm body - Similar Threads
Cherokee Hard Body for 324mm Defender JatoTheRipper Traxxas TRX-4 12 06-01-2019 11:16 PM
proline jeep body kakachille Axial Wraith 7 03-07-2013 08:38 PM
Body Post for Proline Jeep body Avyman92 Axial SCX-10 4 01-26-2011 06:12 PM
Proline Jeep JK body jkwrangler08 Paint and Body 14 09-06-2010 10:07 AM
