Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Aftermarket Brushed Motor Question
Old 04-24-2019, 11:10 PM   #1
Default Aftermarket Brushed Motor Question
First off, I'm still pretty new to RC stuff so forgive me if these questions seem silly, I'm here to learn .
It says on the stock TRX4 motor that it's reversed, so if I pick up something like a Trailmaster Sport 550 21T, which I believe is forward rotation, does that mean that I have to just solder the red and black leads to opposite color ends on the motor or is it more complicated than that? Could I solder normally and just reverse my radio? Any suggestions for motors fro the TRX4? I use it for hiking, as well as, crawling and have a max budget of $60.
About to install the hobbywing 1080
Thanks for reading!!!
RockEFella is offline   Reply With Quote
Old 04-25-2019, 12:09 AM   #2
Default Re: Aftermarket Brushed Motor Question
You're absolutely correct in your thinking. So long as a motor does not have any timing advance (the trailmaster sport has 0° fixed timing) you can simply reverse the leads with no ill effects.
TheLetterJ is offline   Reply With Quote
Aftermarket Brushed Motor Question - Similar Threads
Brushed motor upgrade question Vitamin J Axial RR10 Bomber 9 09-26-2017 11:07 PM
Brushed Motor Timing Question Lou-Dog Electronics 5 05-12-2012 09:38 AM
Brushed motor question EMUTT Electronics 5 08-06-2011 08:59 AM
Brushed motor question Synister_Intent Team Losi Comp Crawler 16 12-12-2009 01:36 PM
