05-06-2019, 09:15 AM | #1 |
I wanna be Dave Join Date: Apr 2012 Location: Merrill, WI
| Motor forward kit
GRC TRX4 G2 Motor Pre-gear Box T4 Front Electric Motor Kit V8 Compatible for 1/10 RC TRX-4 https://www.amazon.com/dp/B07PN96TN3..._L2e0CbREZ0DYN Anyone tried this? I'm thinking about trying it. Sent from my Vivo XI+ using Tapatalk |
05-06-2019, 09:19 AM | #2 |
RCC Addict Join Date: May 2007 Location: pasadena, tx
| Re: Motor forward kit
The servo will be "throwing" the wrong way. which can cause funky steering, otherwise it looks nice.
05-06-2019, 05:12 PM | #3 |
Rock Stacker Join Date: Apr 2019 Location: Canterbury, NH
If moving weight forward is the goal of this kit, there are other ways to do it that are cheaper. Brass bumper mounts, metal front bumpers, adding a winch, etc. I'd also be concerned about the fact there's more u-joints to worry about. But be advised, I'm a newbie to the crawler scene, so take my advice with a grain of salt (and pepper ) It does look like a well designed kit though |
05-06-2019, 08:35 PM | #4 | |
Quarry Creeper Join Date: Nov 2018 Location: Oakley
| Re: Motor forward kit Quote:
Does no one here drive downhill lol? | |
05-06-2019, 08:51 PM | #5 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
| Re: Motor forward kit |
05-07-2019, 06:47 AM | #6 |
Rock Stacker Join Date: Apr 2015 Location: Uvalde
| Re: Motor forward kit I have that setup on my trx and I love it. And the fit is amazing. It goes well with the Holmes hobbie stubby brushless motor I’m running too. Sent from my iPhone using Tapatalk |
05-07-2019, 06:49 AM | #7 |
Only thing is that its a 3 part setup. You need to order the kit, servo Mount, and strut bar/body mount kit for it all to work proper. Sent from my iPhone using Tapatalk |
05-07-2019, 01:52 PM | #8 | |
Sent from my Vivo XI+ using Tapatalk | |
05-07-2019, 02:47 PM | #9 |
Did the installation of the GRC front motor kit quiet the gear noise? Overall how is it working for you?
05-07-2019, 02:56 PM | #10 |
It comes with special washers that greatly help with gear noise. Mine is heavily lubed and is fairly quiet. Sent from my iPhone using Tapatalk |
05-07-2019, 02:58 PM | #11 |
05-07-2019, 03:00 PM | #12 |
05-07-2019, 03:24 PM | #13 |
05-07-2019, 04:13 PM | #14 | |
Firstly you can turn down the drag brake on the fly for when you're descending which is a huge help. Drag brake ramp (various settings for how quick or slow it ramps up to full strength drag brake) makes it so even if you dont turn down the drag brake it can engage gently without upsetting the truck (slamming on the brakes and flipping end over end). The biggest thing I feel though is from the drag brake implementation. Castle has made it so the drag brake is active while going slowly and it helps to keep the motor speed steady. Other ESC's will freewheel when they get to a steep slope (with throttle input) while the X's will keep the speed in check, you can actually hear the spur gear sort of catching up with the pinion as it adjusts the speed. I just installed a few of the Mamba micro X's into some front heavy rigs (Ascender, Venture) and they have dramatically improved compared to what they used to be. I used to stand at the bottom of hill ready to catch these but now they're so much better that I no longer worry. The biggest issue I see with a front heavy rig is a strong drag brake, if you had none at all you'll miss the moments where your back end tries to overtake the front (flipping). to avoid this you can turn the drag brake way down but then it becomes fairly useless. all the drag brake adjustments I listed above address this drag brake related issue. For me this was such a big improvement that I don't see this as a hindrance anymore. Nate you're welcome to give my rigs a spin at Proline BTF and feel it for yourself Last edited by HumboldtEF; 05-07-2019 at 04:28 PM. | |
05-07-2019, 04:36 PM | #15 |
05-07-2019, 04:51 PM | #16 | |||
That's what she said! Quote:
The HobbyWing 1080 is my second choice and while that's much cheaper it's also a lot less adjustable and has less features. There's a huge price and performance gap there that an aspiring manufacturer could fill. | |||
05-07-2019, 04:59 PM | #17 |
Totally agree with you Jato, though it took me a while to come to that conclusion. JRH mentioned in the Have tech questions? Will answer. thread that: He also said the Aux feature might be coming a year ago (which still has not been added) so take that with a grain of salt. If it does happen it would be great though. I really like how open and willing to share info he is. Oh and active freewheeling is what I was trying to describe, its truly an awesome feature that everyone should try if the opportunity arises. Last edited by HumboldtEF; 05-07-2019 at 06:23 PM. |
05-08-2019, 06:07 AM | #18 | |
05-09-2019, 10:26 PM | #19 | |
Quarry Creeper Join Date: Feb 2011 Location: USA
TRX4 subtle upgrades | |
05-09-2019, 10:28 PM | #20 |
Motor forward kit - Similar Threads | ||||
Forward motor mounting | rs10man | Vaterra Ascender | 7 | 08-27-2017 11:09 PM |
Forward motor mount | akatz | Axial SCX-10 | 1 | 02-02-2016 08:04 PM |
battery forward kit | tnt-salvage | Axial Wraith | 5 | 06-23-2013 06:59 PM |
