Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: GTS Long shocks - Bump Stops??!
Old 05-15-2019, 04:09 PM   #1
Default GTS Long shocks - Bump Stops??!
Picked up a set of the long GTS shocks only to find this half inch long bump stop taking up a ton of travel. Is there any real reason to keep these on?? Is it something to do with limiting fluid compression?! Seems like a waste of perfectly good travel to keep them on...what's the point of longer shocks then?!
rc10mike is offline   Reply With Quote
Old 05-15-2019, 10:56 PM   #2
I believe it has to do with limiting travel for the long arm kit so it doesnt hit the lowered servo mount.
My research on the shocks suggets the shaft is 10mm longer and the body is 10mm longer so you should be able to just remove the bump stops and use the full travel.
Ive been getting ready to try longer shocks, but not the long GTS ones. I already bought some taller shock towers.
mass-hole is offline   Reply With Quote
Old 05-17-2019, 07:07 PM   #3
Default Re: GTS Long shocks - Bump Stops??!
It's to stop the pan hard bar from smashing into the differential at full flex on the trx-4 with the lift kit.
Sent from my SM-G955W using Tapatalk
MODC is offline   Reply With Quote
GTS Long shocks - Bump Stops??! - Similar Threads
axle stops/bump stops limit axle upward movement meanbgreen General Scale Talk 7 01-27-2012 03:02 PM
remove bump stops from shocks callahanc83 Axial SCX-10 6 06-24-2010 10:15 AM
Bump stops? starvenamrvin General Scale Talk 3 01-27-2009 02:03 PM
RC bump stops RockCrawlingKid General Crawlers 8 01-11-2008 05:34 PM
bump stops GOMUDN General Crawlers 10 05-12-2006 06:28 AM
