Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Mini T springs on TRX4 shocks
Old 05-29-2019, 03:06 PM   #1
Default Mini T springs on TRX4 shocks
I know that on the bottom I can swap over to big bore shock ends and then use mini T spring cups but has anybody come up with something to secure and center the spring to the upper shock body?
dpcardoza is offline   Reply With Quote
Old 06-04-2019, 02:20 PM   #2
Default Re: Mini T springs on TRX4 shocks
Stay tuned. Im working on something
redemon is offline   Reply With Quote
Old 06-05-2019, 06:08 AM   #3
Old 06-06-2019, 02:22 PM   #4
These have a 12mm ID.....they should fit. https://www.fishscrawlerparts.com/st...per_set.html#/
pdm56 is offline   Reply With Quote
Old 06-10-2019, 09:29 AM   #5
I hope to have a solution soon. Waiting on some parts to get here. Until then look at the point im at now.
Old 06-10-2019, 01:36 PM   #6
Does that spacer limit uptravel?
Also, what is the advantage of a mini spring like this?
mass-hole is offline   Reply With Quote
Old 06-10-2019, 01:47 PM   #7
Main advantage is Droop.
Its not for everyone though.
I run droop on every rig I have.
Old 06-10-2019, 02:06 PM   #8
I guess i domt understand what running droop means. Meaning you run deep in the travel so you have lots of downtravel at static ride height?
Old 06-10-2019, 02:08 PM   #9
Yes. Makes the truck sit at its lowest point.
Old 06-10-2019, 02:25 PM   #10
Moderator
JatoTheRipper's Avatar
What is your point in doing this?
Old 06-10-2019, 03:58 PM   #11
I am guessing because the stock springs won't let you run insane droop without also lifting off the bottom spring seat when at full extension. If you can even get a lot of droop in the first place with the stock spring.
Old 06-10-2019, 03:59 PM   #12
Moderator
Crap. I just saw you answered it above as well. Thanks.
Old 06-11-2019, 01:22 PM   #13
Same reason the big bores and mini t spring kits exist.
Lots of people have the trx shocks on other platforms so there will be folks that want this setup for comp trucks.
Old 06-11-2019, 03:27 PM   #14
So are you literally riding on bump stops at static ride height with this or is there a little compression left?
Old 06-12-2019, 06:40 AM   #15
Would all depend on the spring setup. They have Soft, Medium and Firm springs.
But yes it will sit at its lowest possible way when sitting.
Old 06-13-2019, 12:09 PM   #16
Great post.
Suspension: "Droop" (The What, Why, and How)
Old 06-13-2019, 12:16 PM   #17
That's correct. The COG if very low due the rig sitting bottomed out. Like mentioned above, it's not for everyone. However, if you take a look at larger comps around the L48 you'll notice it's quite popular. You can still avoid high center situations with a correctly timed throttle bump on approach.
I personally run Big Bores w/ ultra soft miniT springs and 80 weight oil.
GTSLOW is offline   Reply With Quote
Old 06-13-2019, 06:36 PM   #18
Originally Posted by pdm56 View Post
I actually found that on a google search. After reading i still was not 100% sure if droop meant fully bottomed out or if ut just meant you run more droop than compression.
I am kinda running a mild droop setup with my long travel shocks. It sits pretty close to full compression at stock ride height but has lots of droop available.
Old 06-16-2019, 07:02 AM   #19
Shocks are not bottomed. 40% droop. Works great.
Old 06-16-2019, 09:10 AM   #20
I’m curious because I can’t tell from the pic. Is the bottom spacer solid limiting up travel?
Mini T springs on TRX4 shocks - Similar Threads
Mini T springs inside Maxx shocks? Trike Kid Tamiya TLT Crawlers 0 05-29-2005 08:47 PM
