08-02-2019, 11:05 AM | #1 |
Pebble Pounder Join Date: Aug 2019 Location: Rancho Cucamonga
| Tools/supplies needed for kit build
I'm prepping my work area and getting ready for my build. What tools and supplies should I have? I already have most of the basic hex hand tools, soldering iron, dremel, tire glue, etc. Anything else I should make sure I have on hand for assembly? Thanks! Last edited by toys222; 08-02-2019 at 11:56 AM. |
08-02-2019, 12:45 PM | #2 |
| Re: Tools/supplies needed for kit build Depends what you call basic tools. MIP makes nice quality set of drivers (1.5, 2.0 and 2.5mm tips) also make set of socket drivers (you'll want 5.5 and 7.0mm), good set of needle nose pliers, lexan scissors (Kyosho or Dubro), that should do since you've got soldering iron, Dremel and CA. |
08-02-2019, 11:29 PM | #3 |
Lexan scissors! I think it's time to refresh my pair. I've used those suckers for everything! Thanks! Sent from my SM-G960U using Tapatalk |
08-02-2019, 11:39 PM | #4 |
Quarry Creeper Join Date: May 2019 Location: North Highlands
X-acto and flush cutters are pretty handy too.
08-03-2019, 02:07 AM | #5 |
Newbie Join Date: Jun 2019 Location: Cali
I just worked on the sport kit..it pretty much came with everything. An electric driver would have been really handly..but I found the supplied hex wrench is less straining than a screw driver.
08-07-2019, 02:12 PM | #6 |
| Re: Tools/supplies needed for kit build I have a nice electric driver, but it's a larger Dewalt. Is there a smaller electric driver that anyone would recommend? I can see that being handy and a nice addition to the RC tool bench!
08-07-2019, 02:23 PM | #7 | |
| Re: Tools/supplies needed for kit build Quote:
https://www.amazon.com/gp/product/B005LTNLDS | |
08-07-2019, 03:19 PM | #8 | |
Can you also recommend a bit/accesssory kit to go along with it? | |
08-07-2019, 03:29 PM | #9 | |
I use these. You might find some cheaper but beware of soft metal ones, there's some real junk out there. https://www.amazon.com/VEGA-Power-Bi...M67/ref=sr_1_8 | |
08-07-2019, 03:38 PM | #10 | |||
X2, PCB (printed circuit board) flush cutter, buy the good ones, just don't cut piano wire with them. Quote:
08-07-2019, 03:51 PM | #11 | ||
| Re: Tools/supplies needed for kit build Ha, think we've all learned that one the hard way. Quote:
Quote: | ||
08-07-2019, 04:53 PM | #12 | |
Good to know, thanks. Buy good drivers and many less rounded out fasteners and the tools will last a long time if not abused. | |
08-07-2019, 05:15 PM | #13 |
| Re: Tools/supplies needed for kit build Oh, I learned that a long time ago. All my hand drivers are top notch for sure. But those dang bits, I just can't keep track of em. And since I hand tighten/loosen everything anyway, they do the trick for me just fine. Still have to find good ones though, there's some real junk out there |
08-08-2019, 10:18 AM | #14 |
Thanks for all the suggestions! I just ordered that B&D driver and those MIP bits! |
08-08-2019, 03:50 PM | #15 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
Aside from everything said above, Blue loctite and some strong double sided tape, maybe shoe goo/e6000.
08-09-2019, 06:48 PM | #16 |
Driver, hex bits, and new work mat arrived today. Getting closer to getting started on this build! Sent from my SM-G960U using Tapatalk |
08-09-2019, 06:54 PM | #17 |
You have more patience than I, lol. I would have been turning screws by hand!
08-10-2019, 12:37 PM | #18 | |
Sent from my SM-G960U using Tapatalk | |
08-14-2019, 11:31 AM | #19 |
Thanks again for recommending the power driver. It actually makes assembly SO much easier than doing it all by hand. I still do the final tighten / torque by hand, but the driver saves so much time and wrist fatigue. Sent from my SM-G960U using Tapatalk |
08-14-2019, 01:18 PM | #20 |
You bet. Don't know what I'd do without mine |
Tools/supplies needed for kit build - Similar Threads | ||||
Needed RC tools - general and for Wraith Kit | 2Crawl | Newbie General | 7 | 10-03-2013 08:12 AM |
Rally Race Track Supplies Needed | neillarson | Illinois | 9 | 05-11-2011 05:00 PM |
1/6th scaler Cooler and first aid kit supplies. | reddevildemo | Scale Accessories | 3 | 01-22-2011 11:10 PM |
what tools are needed to build the kit | Empire932 | Axial AX-10 Scorpion | 8 | 07-21-2009 12:01 PM |
