Traxx ratio compared to wheels Anyone know the ratio of the tracks compared to having normal wheels on the rig. It'd be awesome to run tracks on the back and wheels on the front. Thanks Sent from my SM-G975F using Tapatalk |
Re: Traxx ratio compared to wheels Measure the OD of the tires and the OD of the drive sprocket. Calculate the percent difference between them and that will give you an indication of the difference needed in gearing. I suspect the drive sprocket will be very close to running a conventional wheel with no tire mounted. |
Re: Traxx ratio compared to wheels Quote:
https://youtu.be/dqcwH4hIrtw Sent from my SM-G950U1 using Tapatalk |
