Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Front clicking noise
Old 10-28-2019, 05:05 PM   #1
Default Front clicking noise
Hi all, my TRX4 Has developed a clicking noise in the front end. Whenever both wheels are on the ground and moving I can hear it. However, if I hold the truck and give it throttle while lifting one front wheel off the ground it goes away. It doesn’t matter which side. Would this be in the axle ring & pinion?
Thanks in advance
twentyniner is offline   Reply With Quote
Old 10-28-2019, 05:30 PM   #2
Default Re: Front clicking noise
Could be a nearly shot bearing in the front end as well. Only way to tell if it's really the ring and pinion is to take them out and look.
Sneetches is offline   Reply With Quote
Old 10-28-2019, 06:04 PM   #3
Thanks, will do that when I can. It’s a weird noise, more like plastic clicking than a metal sound. But I’ve never stripped anything before, (first crawler) so have no frame of reference.
Old 10-29-2019, 12:05 AM   #4
Could also try checking your gear mesh, and making sure your driveshafts screws are parallel with eachother. That fixed mine.
aqualungs is offline   Reply With Quote
Front clicking noise - Similar Threads
Clicking noise? RockBuggyKiller Axial SCX-10 7 07-07-2014 03:28 PM
Clicking noise... bur1196 HPI Wheely King 10 05-05-2011 07:23 PM
Awfull clicking noise??? Kamikaze Tamiya TLT Crawlers 20 08-29-2006 04:05 PM
1/18 jeep makeing a clicking noise in front axle chadw_3 General Crawlers 7 09-26-2005 08:13 AM
