80mm Shocks? I'd like to lower my TRX4 slightly in the interest of scale, and wondered if I can simply change the stock shocks to these? GPM Racing Aluminum Ball Top Damper (80mm) With 1.2mm Coil Spring & Aluminum Collars & Washers & Screws & Dust-proof Black Plastic Cover - 1pr Set Black DP080 |
Re: 80mm Shocks? Quote:
Ernie |
Re: 80mm Shocks? Tra2659 are the big bore equivalent to 80mm. I’d recommend a new rebuild kit to go with them as the last set I ordered was from the 90s and the rubber diaphragm and o rings were hard and dry |
I agree with Ernie - Keep the shocks and just run 10mm of fuel line under the piston to limit the travel or stroke to 80mm. Cheap, easy and effective. "thumbsup" |
Re: 80mm Shocks? Yes. We'll kinda. This limits the down travel. Depending on your build it may not make you sit lower. You can steal the pen springs out of clicky pens and put those inside the shocks. That would work better then gas line imo. If you can mount the top higher or further forward or back would be better imo. Do they make extended shock towers for the trx4? Lighter weight springs would be good too. Sent from my SM-N950U using Tapatalk |
I've done both mods. As far as "working better", it depends on what all the OP is after. Pen mod will assist more in stancing the truck lower. Fuel line or similar works better for a purely, static limiter. If he's after more "scale" articulation, versus pronounced "flex", the fuel line will definitely achieve that. The pen spring mod will allow for more of the down stroke of the shock (minus the fully compressed length of the internal pen spring). What I have not done is a combination of the two. Might be interesting to do 5mm of fuel line and the pen spring mod - Determine spring length to get it so the fully compressed length is 5mm. So you end up with -10 mm to get 80mm and you achieve the lower stance and limit articulation for a more "scale" appearance. Not really my thing as I'm not one to intentionally inhibit a trucks performance, but in theory, I could see how it would work very well to achieve that desired scale affect, especially while the rig is functioning on the trail / rocks. |
Re: 80mm Shocks? If the length of the fuel line is shorter the the resting compression of the spring sag or preload, the truck will not sit any lower. This is why I would suggest the pen mod. Sent from my SM-N950U using Tapatalk |
Re: 80mm Shocks? Personally I like the desert lizard shocks. They come with a bunch of springs and are very adjustable. They also do droop setups that can lower the truck like you want. Sent from my SM-N950U using Tapatalk |
Re: 80mm Shocks? Great discussion benefiting me, so thank you gentlemen. I'm really after more scalish looks than overall performance given I won't likely be going any further than my own backyard given my disability. I am somewhat limited in my shock selection here in Canada and any purchases stateside over $70+ often get hit with duty taxes at the border + the exchange rate sucks. I have been looking at the G-Made products available here, including the Transition series which has a 'droop' setup option. |
