11-21-2019, 06:31 PM | #1 |
Newbie Join Date: Feb 2014 Location: SFO
| TRX4 axles
I am looking to do a build with a VS4-10 chassis and TRX4 axles. The plan is for locked axles. What is the difference between the TRX4 Sport axles and the TRX4 Defender axles in terms of durability?
11-21-2019, 06:45 PM | #2 | |
Quarry Creeper Join Date: Oct 2019 Location: Perry
| Re: TRX4 axles Quote:
The Sport axles are locked, and the Defender axles have the ability to be opened up via cable and servo. So you want Sport axles Sent from my iPhone using Tapatalk | |
11-21-2019, 07:20 PM | #3 |
Rock Stacker Join Date: Mar 2012 Location: ohio
| Re: TRX4 axles
It seems like the sports are easier to find and cheaper cause the lack of the switchable locker
11-21-2019, 07:30 PM | #4 |
| Re: TRX4 axles |
11-21-2019, 07:35 PM | #5 |
| Re: TRX4 axles |
11-21-2019, 07:59 PM | #6 |
Quarry Creeper Join Date: Apr 2018 Location: US
| Re: TRX4 axles |
11-25-2019, 01:12 PM | #7 | |
But the vs4-10 chassis is not so different from the trx4 chassis. Mostly shock mounts and transmission makes it different. I would just buy the sport myself. Unless you want a really low gear ratio. Sent from my SM-N950U using Tapatalk | |
11-27-2019, 07:14 AM | #8 |
Quarry Creeper Join Date: Oct 2011 Location: Land of earthquakes
| Re: TRX4 axles
I did that, it has great ground clearance all around but the diff ratio is too short, i have a Castle slate 2850 kv and i had to use a 44t spur and 23t pinion to have decent wheel speed with 3s and crawl well with excellent low speed control, also make sure that you mount the transmission with the output in line to the front differential |
TRX4 axles - Similar Threads | ||||
Trx4 axles used on builds | trascall10 | Traxxas TRX-4 | 7 | 01-24-2020 10:04 AM |
TRX4 axles under an SCX? | skybolt | General Crawlers | 2 | 04-03-2019 10:28 AM |
bomber trx4 axles | steven318is | Axial RR10 Bomber | 6 | 07-30-2018 08:20 PM |
