12-30-2019, 05:38 PM | #21 | |
Rock Crawler Join Date: Jan 2006 Location: In the basement
| Re: New TRX4 Questions. Quote:
I'll hunt the TSL's down. I had a set of TSL's once for my Jeep. I'll give them a go on a scaleish truck. Do they fit the RC4wd beadlocks pretty well? I know back in the past some of the proline tires had a thin bead and not all proline tires held well in them. | |
12-31-2019, 12:31 PM | #22 |
Sorry for the double post, but they do not fit the RC4WD beadlocks that I have. Its nearly impossible to clamp the beadlock, and if you do get it clamped the tire pulls right out. So I'm back off to the hobby shop to see what else they may have in stock. They had a set of vanquish I may pick up.
12-31-2019, 01:44 PM | #23 | |
12-31-2019, 06:43 PM | #24 |
Pebble Pounder Join Date: May 2019 Location: Henderson, NC
I've had my TRX4 about 5 months, and I certainly am NOT an expert about any of this. But your 3S batt comes to my mind... I've noticed that loose dirt seems usually the most difficult to deal with on an incline - that and 3+ inches deep of leaves. I've also noticed a world of difference between 1st gear and 2nd gear in the loose stuff, and (as you'd expect) a world of difference between locked and unlocked diffs. I'm running a 2S batt and I was amazed at the traction difference between 1st gear vs. 2nd gear at a dead stop to barely moving... even though I squeezed as light as I could, 1st gear would allow truck to move in many places where 2nd gear always spun tires. I've not yet tried a 3S but I'm told it's basically faster. So maybe running a 3S is like giving up lower 1st gear because you just can't squeeze gently enough for the increased 'horsepower'? |
01-01-2020, 10:34 AM | #25 | |
| Re: New TRX4 Questions. I've had them for quite a few years now. Nothing they have on their website now are exactly like it. On mine the rings clam via thru bolts to the actual wheel. I picked up some of the vanquish ones that worked better. I wish they didn't have 1000 screws, but they work. Quote:
Gearing takes leverage away from the motor and adding power keeps the motors mechanical advantage but, adds umph. I don't think the added power is the problem, its likely more in the weight area. However, I don't know that dropping to a 2s battery would be enough to make a notable difference. I'm going to go out and check out a new ESC or external bec and servo today. I've got a hitec 7980 floating around with some 7955s from my giant scale stuff but I don't think the traxxas built in BEC is going to have the balls. I hate soldering but I'm going to go look at the castle bec or a hobby wing esc. Would the 3 amp bec be enough for the truck, or should I really get the 10 amp and solder it all in. | |
New TRX4 Questions. - Similar Threads | ||||
Hobbywing 1080 on TRX4 Blazer questions! | Mudsplat79 | Electronics | 20 | 11-13-2019 10:39 PM |
Questions on buying a used TRX4 | noride | Newbie General | 6 | 10-16-2019 10:52 AM |
Purchasing a trx4 bronco this month. Have a few questions. | ChasD_82 | Traxxas TRX-4 | 6 | 07-30-2019 01:23 PM |
TRX4 Shocks Questions | Bix | Axial SCX10 II | 2 | 01-22-2019 03:00 PM |
TRX4 receiver channel questions | Levi | Traxxas TRX-4 | 1 | 11-08-2017 07:37 PM |
