My 3 days old TRX 4 is making nasty noise while turning Hi everyone, I'm trying to figure out what could be wrong with my TRX4 When I fully turn left or right, the truck is making very weird grinding noise. I'm not able to figure out where it's coming from. Any idea, also I don't understand why it's only happening when I turn the wheel fully. Here's a small video https://www.youtube.com/watch?v=4W6JyhPqPWY If I remove the front wheels, there's no grinding |
Re: My 3 days old TRX 4 is making nasty noise while turning Have you set the end points for the front drive L & R? That keeps the U joint from jamming, caused by a tight turn. Can see it in the video, notice the vibration of the spindles, pep |
Re: My 3 days old TRX 4 is making nasty noise while turning Quote:
Re: My 3 days old TRX 4 is making nasty noise while turning Not sure what wheels/ wheel hardware you're running but are you sure that it's not your wheel bolts making contact against the portal covers? Or the back of the wheel hex? |
pep |
Well.. no idea if OP has taken the wheels off to inspect for possible contact issues.. Sometimes it's the simple things. |
So both wheels have gone loose the same amount and at the same time. That make any sense? Just taking stuff a part for the hell of it, can and does in most cases, make things worse . The word is troubleshoot, not my problem, however knowing there in an end point radio adjustment I be trying that FIRST. "Well it did not do it before" is not a logical reason to dismiss the idea. pep |
I took apart the cv joint cleaned it and polished both the joint and the internal shaft where it is rubbing against the joint. I also added marine grease. Now it’s much much better, it’s slightly binding only at full lock and when driving the vehicle it behave exactly like when it was just out of the box. |
Re: My 3 days old TRX 4 is making nasty noise while turning I'll just add that this chatter is normal though the noises yours made is a bit off putting. You'll also find that this chatter is particularly extreme when the truck is on its lid and this is mainly due to the fact the the moderately heavy wheels exacerbate this chatter by throwing their weight around. Put the truck on the ground and drive it and you'll get some minor chatter but nothing like when its on its lid. This is simple the nature of universals that are being maxed out. Personally I dont worry about it because I try to drive shiny side up :mrgreen: Its not the first time this has been asked either, you can read more and see another video same as yours here http://www.rccrawler.com/forum/traxx...ls-turned.html |
