01-08-2020, 07:22 AM | #1 |
Newbie Join Date: Dec 2018 Location: Alberta
| TRX4 Kit - any build tips?
Hi all, I will be taking delivery of my trx4 kit (w/Bronco body) and some supporting components over the next week or 2. I ended up purchasing the following: - trx4 kit - bronco body - 2 turnigy 2200mah 3s - hota D6+ charger - ds 3218 pro servo - traxxas stainless steel screw kit - traxxas metal servo horn. - Hobbywing 1080 Not sure if the screw kit is necessary, but I figured ‘why not’ since I am building from scratch. From what I have read the kit is pretty well put together, but wondering if anyone experienced any ‘gotchas’ while building or have any tips for completing certain steps. Thanks! Last edited by Foghat; 01-08-2020 at 08:58 AM. |
01-08-2020, 07:25 AM | #2 |
Newbie Join Date: Sep 2017 Location: Canada
| Re: TRX4 Kit - any build tips?
Careful with the screw kit, I don't know if I just got a bad batch or something, but I found them very weak...snapped 2 heads off like butter...what a pain. Sent from my SM-G973W using Tapatalk |
01-08-2020, 08:40 AM | #3 | |
| Re: TRX4 Kit - any build tips? Quote:
I see you ordered the metal servo horn. I did the same and my Sport kit ended up coming with a metal servo horn so now I have a spare. Stainless steel screw kits are mainly used to prevent rusting hardware. Others use it for looks. Stainless is weaker than most other hardware, but I've never snapped a screw on any of my RC's. I have to say the standard hardware included with Traxxas RTR's and kits is very nice and I've never upgraded it to SS. You may want to have a little, electric screwdriver with MIP speed tips. Traxxas plastics are good and it gets tiring to screw all of the screws in by hand. Other than that I can't think of any warnings to give you. It's a very fun build and the manual is excellent. Is it your first RC build? Last edited by JatoTheRipper; 01-08-2020 at 08:44 AM. | |
01-08-2020, 09:05 AM | #4 | ||
Yes I got the kit with electronics. I can’t believe I forgot the hobbywing 1080 in my list - I bought that as well. Updated first post. Hmmm. I thought stainless steel was stronger than the included screws. Will have to rethink whether to use them or not - I’m not terribly concerned about rusting. I have built three kits over my long on again/off again relationship with the RC hobby. Most recent was a about 4 years ago - a losi 8ight-e 3.0. | ||
01-08-2020, 09:22 AM | #5 | |
You'll have no problem building this kit then. | |
01-08-2020, 03:54 PM | #6 |
Newbie Join Date: Dec 2019 Location: Miami
Sport kit by the sounds of it so no micro servos, 7.4v should be fine. Those 20kg servos work fine on the Traxxas ESCs though IME. SS is weaker generically speaking which is why you don't tend to see them in high stress spots. Should be fine though but, IMO, money I would have put elsewhere unless you are planning on getting it wet a lot. |
01-08-2020, 08:13 PM | #7 | |
Maybe I will skip the SS screws. Was sort of a last minute impulse buy. | |
01-09-2020, 06:43 AM | #8 |
I wouldn't...nearly every TRX4 I see has rusty screws somewhere. Drives me nuts personally. I don't think there there's any part that will stress the screws so much they fail, I can't see strength being an issue at all. Just be sure to lube the threads a bit when screwing into plastic - the biggest issue I've had with them is they can strip the head if too much torque is applied. |
01-09-2020, 06:46 AM | #9 | |
Sent from my SM-G973W using Tapatalk | |
01-09-2020, 06:58 AM | #10 | |
01-09-2020, 07:51 AM | #11 | ||
OSRC is right. SS screws are softer, but you shouldn't have an issue in a scaler like a TRX-4. The bashers are the ones that typically break SS screws. I've used SS screw kits in other scalers and crawlers without any breakages. | ||
01-09-2020, 10:13 AM | #12 | |
01-09-2020, 07:07 PM | #13 |
Newbie Join Date: Oct 2019 Location: Brandon
I just got the kit for Christmas. I went ahead and purchased the ss screw kit, I think it is worth it.
TRX4 Kit - any build tips? - Similar Threads | ||||
TRX4 Build Kit 12.3?? | rayraypc | Paint and Body | 7 | 07-25-2019 09:48 AM |
trx4 sport kit build | traxxas79k5 | Traxxas TRX-4 | 0 | 05-20-2019 07:35 AM |
New kit build, need tips to help it not flip so much | awdtsi | Axial Yeti | 22 | 04-20-2015 03:00 PM |
Suggestions & Tips for Rubicon Kit Build | Parker21 | Axial SCX-10 | 5 | 01-20-2014 03:43 PM |
Dingo Kit - My first build. Any tips/advice? What mods are worth doing? | LeadFootCaliKiid | Axial SCX-10 | 2 | 01-06-2014 03:51 PM |
