Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: TRX-4 2017 Jeep JK
Old 07-15-2018, 02:48 PM   #1
Default TRX-4 2017 Jeep CRC JK
I must be crazy to start another project without finishing up the the others but that's no fun. So a couple of weeks back while at the LHS I am across this on the shelf
I couldn't pass it up so it came home with me. I have been trying to get my hands on one for some time now. I originally wanted to this as my first build but couldn't get a body. I know Proline has a drop on body for the 12.8 but always wanted the Axial 2017. The screw on fenders look much better than the lexan ones to me plus I have the opportunity to order more Knight Customs designs for the Jeep. I know it's going to be difficult as the body doesn't fit the TRX-4 chassis. So here we go.
carpetfuzz17 is offline   Reply With Quote
Old 07-15-2018, 03:02 PM   #2
Default Re: TRX-4 2017 Jeep JK
I picked up a kit couple weeks back and slowly working on it. Just trying to get a rolling chassis that I can work with. I learned my lessons from the previous TRX4 so I know what to change from the start. Not going to boredom anyone to death with the building process but did do one thing different. I inspected all the bearings and for good reason. Found several with no grease in them.
I packed new grease in the the bearings would hate to have one fail. Yes it is a lot of grease but being a crawler to me it's no big deal
Old 07-18-2018, 07:55 PM   #3
I was able to get a little bit more done today. The frame rails are way to long so let the cutting begin.
Once I got them cut off time to test the body and to me it lines up using the front RTR body holes
I know it's sitting a little high but that is going to adjusted
Old 07-19-2018, 01:24 PM   #4
It's time to tackle the rear inner fenders. This was one of the biggest reason I wanted to do this body was so I could add the inner fenders. With the frame cut down the fenders really stick out.
Trimmed up and ready for testing
Old 07-19-2018, 04:09 PM   #5
Can you take some out in the flat area between the shock tower & rock light?
AnimalHippie is offline   Reply With Quote
Old 07-19-2018, 04:29 PM   #6
I had thought about that but wasn't sure when it got put back together if it would hold up. I really almost split it but decided against it. With the drop parts I can play around with those to see what works best. Its not problem to pick up new fenders and redo
Old 07-19-2018, 07:55 PM   #7
When I got home from work today I seen my Hong Kong midnight special had shown up. This is what happens when you stay up late on EBay. I am not expecting high quality but they actually look decent. I figured for $10 shipped I will try them out. If they don't work out to the parts bin they go.
Old 07-19-2018, 08:39 PM   #8
$10 ? ?? Did you have a coupon or something?
Old 07-19-2018, 08:56 PM   #9
Yeah I had $25 coupon. So I figured what the heck.
They are actually looking decent and heavy. I will weigh between them and stock to see how much difference there is.
Old 07-19-2018, 09:01 PM   #10
I have two sets of those Xtra Speed axle housings and really have no complaints. Typical price for the pair is around $56 which is still a good deal.
Inspector86 is offline   Reply With Quote
Old 07-19-2018, 09:10 PM   #11
I found them for $17 each free shipping
Good to know someone else is using them as well with no complaints
Old 07-20-2018, 09:05 PM   #12
Default Re: TRX-4 2017 Jeep CRC JK
Managed to get the Knight Customs bumper and rear fenders done tonight so far so good. Everything is fitting nice. Had to cut out the fenders to let the light buckets to drop into place. Not a big deal as you can't see them once the body is on.
Old 07-20-2018, 09:13 PM   #13
Awesome looking build
iridebikes247 is offline   Reply With Quote
Old 07-20-2018, 10:05 PM   #14
thanks for the comment
its far from done still have the front fenders to tackle then on to the rest of the build. up after that is the body
Old 07-22-2018, 01:06 PM   #15
Had some free time yesterday and hit up the local Harbor Freight. I know that the quality isn't the highest but some stuff is actually not that bad. That said I was after a little digital scale to weigh some items just to get an idea of the differences.
I started with some weight that was already stamped to get an idea how accurate it was. Close enough for me.
Old 07-22-2018, 01:13 PM   #16
Here is the numbers that I have come up with. They were each weighted with the same hardware to get the best results.
STOCK
HONG KONG MIDNIGHT SPECIALS
Old 07-22-2018, 01:15 PM   #17
The midnight specials actually went together easy with no bad threads or other defects.
Old 07-22-2018, 08:00 PM   #18
Took a short break and started the front axle
STOCK
HONK KONG SPECIALS
Old 07-23-2018, 08:00 PM   #19
While I was working on the axles I figured that the links needed some attention also. They were starting to rust already and they haven't been outside yet. I know the first rock there goes all the color but I couldn't help myself. I think they turned out nicely.
Old 07-25-2018, 10:36 AM   #20
It's always nice to receive packages while at work. Got my replacement Traxxas ESC now just need to figure out what to do with it
TRX-4 2017 Jeep JK - Similar Threads
TRX-4 Jeep Cherokee carpetfuzz17 Traxxas TRX-4 187 03-14-2021 07:28 PM
Jeep JK TRX-4 Build Crawler505 Traxxas TRX-4 46 05-12-2019 07:16 PM
2017 CRC Jeep Body carpetfuzz17 Axial SCX10 II 10 07-22-2018 08:25 PM
2017 Jeep body width number9 Axial SCX10 II 2 03-31-2018 10:12 AM
