09-24-2020, 10:42 AM | #1 |
Newbie Join Date: Apr 2019 Location: stoughton
| trx4 axles on a gspeed chassis
Good day all, Im building a new gspeed chassis with TRX4 axles. Those that have done this, what links did you use? I made some custom links out of brass based off of the SCX 10ii and thy seem a little short. The wheel base is just about 12 inches, instead of the 12.3 Any suggestions on link lengths? |
09-24-2020, 10:46 AM | #2 |
| Re: trx4 axles on a gspeed chassis
Play around with different length rod ends maybe, you're close.
09-24-2020, 12:07 PM | #3 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
What about Traxxas Jato rod ends? They're a little longer. Sent from my LM-G710VM using Tapatalk |
09-24-2020, 12:14 PM | #4 |
I may have to look into those, I used the TRA5347 ends. Im going to be remaking some links again as high clearance, so I can make them longer and maybe use different rod ends as well to make up the length needed. I need to wait until my body get here though, so I make the links fit the body though.
09-24-2020, 12:22 PM | #5 |
For fabricating custom links, all-thread really is you friend here. I put the whole mess on blocks, get the WB and axle angles where I want them, then take rough measurements. Using the rod-end I am going to use for the actual build, measure those from center eye to the end, your all-thread links should be long enough to engage about half way up the rod end, this gives you some adjustment, if needed.
trx4 axles on a gspeed chassis - Similar Threads | ||||
Thinking of building a truck around a GSPEED chassis. Got some questions. | FloridaST | Newbie General | 16 | 06-05-2020 05:45 PM |
GSpeed Chassis Build - Cloncho's Next Evolution | n_d_fox | 1.9 Scale Rigs | 11 | 05-24-2016 09:49 AM |
