08-20-2022, 10:55 PM | #1 |
Quarry Creeper Join Date: Feb 2016 Location: Pembroke ON Canada
| Trx4 single speed transmission
Hello so my tactical trx4 transmission started as a 2sp now it is a single speed. And it starts getting warm really quick i have no binding parts not to much grease. And the power plant is a HH 3500kv puller pro brushless motor. With a 1/10 castle creation MX esc running 3s 11.1v batteries. And slipper eliminator kit. Drag brake ramp is at the slowest setting, Drag Brake is at 60% was going to lower it a bit like 45% i do a lot of flat terrain walking at the current moment. Still try to get to challenging terrain when i can. What could be causing the transmission to heat up? So much. Gearing is currently being adjusted it sits currently at 14/45 till i find that sweet spot for gearing Sent from my iPhone using Tapatalk |
08-20-2022, 11:37 PM | #2 |
Quarry Creeper Join Date: Jan 2021 Location: in the Canyon
| Re: Trx4 single speed transmission
Well, I run 9/45 with an AXE V2 3300kv, and that still seems a little brisk-- though the gearbox never gets hot. I have to ask-- did you take parts out, or did you just lock it into low gear? When the gearbox heats up, does the motor/ESC get hot as well? Because if they don't, you've got something binding. I have four TRX-4 gearboxes in service here-- three two-speeds and one single speed. None have ever heated up past ambient. |
08-21-2022, 12:11 AM | #3 | |
| Re: Trx4 single speed transmission Quote:
Sent from my FRD-L14 using Tapatalk | |
08-21-2022, 12:23 AM | #4 |
Forgot to mention that I got the hot racing aluminum transmission case not the stock plastic one. Ran it in the yard and it was 32°C outside when I last ran the truck. Sent from my FRD-L14 using Tapatalk Last edited by Schs2013; 08-21-2022 at 12:38 AM. |
08-21-2022, 06:13 PM | #5 |
So did a test of powered the motor up and let it free spinning up to approx* 45% throttle not connected to the transmission the motor started heating up with no load at a certain rpm range. The truck rolls smoothly. Sent from my iPhone using Tapatalk |
Trx4 single speed transmission - Similar Threads | ||||
Beast II R3 Scale single speed transmission conversion? | The Dark Knight | Multi Axle Rigs | 1 | 04-27-2022 03:48 AM |
TF2 Transmission: R3 2-speed vs R3 single-speed vs R4 single-speed | Panther6834 | RC4WD Trail Finder 2 | 9 | 11-05-2019 12:40 PM |
