03-12-2020, 11:19 AM | #1 |
Pebble Pounder Join Date: Jul 2012 Location: Northeast
| Spacing-up the steering servo for more clearance
While making a repair to my TRX-4, I noticed that my Holmes Hobbies SHV500 servo (yes, it's a V1) had a mark on the case where the servo arm is making contact with it. Comparing it with an all-stock TRX, I noticed that the servo protrudes a small bit below the mount. Has anyone ever spaced there servo up for more clearance? I figured I'd just use some washers unless someone suggests something better. Has anyone had any problems with the linkage being at too much of an angle or encountered any other detrimental effect on steering performance? |
03-12-2020, 02:36 PM | #2 | |
| Re: Spacing-up the steering servo for more clearance Quote:
I've used washers and even 3d printed spacers. I think I preferred the spacers because they make installation a bit simpler (2 pieces instead of 4). If you wanted spacers but dont have a printer you could also fab up some out of styrene. Last edited by HumboldtEF; 03-12-2020 at 02:39 PM. | |
03-12-2020, 04:25 PM | #3 |
Thanks for the heads-up. I like the spacer idea. I’ll have to look into that. I was also just thinking about the servo horn. Will a horn with a small drop make more sense? What horns are y’all running? For reference, I used the Traxxas aluminum servo horn that came with my kit. It seems pretty straight with no drop at all that I can tell. |
03-12-2020, 06:38 PM | #4 |
Can you post up a pic or elaborate on what its rubbing? So are you saying the horn itself is too close to the servo? or is it rubbing something on the chassis? I've ground down many a sevro horn to get clearance, just leave enough meat around the threaded holes. If its the horn not clearing the servo case just file the bottom portion of the horn, I just had to do that with a VP horn on a Tekin servo. |
03-12-2020, 07:32 PM | #5 |
Rock Crawler Join Date: Jun 2015 Location: In the Sticks in the Ozarks
I clipped the mounting tabs off an old dead servo and use them as shims to raise mine just a bit. Also filed and polished the arm for clearance. jim |
Spacing-up the steering servo for more clearance - Similar Threads | ||||
How to get Steering Servo Clearance form your Links on a SCX10.2 | Rock Concepts | Videos! | 1 | 12-16-2016 02:10 PM |
Steering clearance | Zrazer | HPI Wheely King | 6 | 01-14-2013 08:14 PM |
Servo Mount and High Clearance Steering Arm | ripper7777777 | RC4WD Bully | 124 | 12-12-2010 06:56 AM |
High Clearance Steering Links | Sinastir | Axial AX-10 Scorpion | 35 | 11-23-2008 06:10 PM |
steering clearance? | Thaadius | Tamiya Clod Buster | 16 | 01-13-2006 06:30 PM |
