04-17-2020, 08:09 PM | #1 |
Newbie Join Date: Jan 2020 Location: osprey
| Trx-4 Sport Weight Question
Hello All, I bought a trx4 sport RTR a couple of months back. I probably should have purchased the kit with all the mods I have done. One of the mods was this: https://hot-racing.com/?partnumber=TRXF100FM01;c=1164 This allowed me to move the serve very far forward. It allowed the have the battery right between the shock mounts and the ESC I believe will fit right behind that. My intended use is pure rock crawling. I wondering what others think about moving all this weight forward and slightly up as well. Do you think it's better to have that weight low and further back? I did a little testing today and it seemed ok up and down the rock I have at the house but I promptly shredded my plastic servo horn with the new savvox servo. As you can see the series very far forward. I have the reviver tray behind that and finally the battery. What is traditional thought on weight far forward and raised versus further back and lower? The other advantage this would allow would be to remove the floorboards and sliders to lighten things up a little. Should I level them on? Is there lighterless bulky slider option? |
04-18-2020, 09:09 AM | #2 |
crawling arizona Join Date: Jan 2011 Location: glendale
| Re: Trx-4 Sport Weight Question
I left it mostly stock position on that stuff and altered mine for the weight to be lower ( metal diff housings, brass bits alum wheels ) with the electronics causing a slight forward bias , seems to plant it better . Not top heavy on side hills, not nose heavy or tail light on steep stuff and at 9 pounds good tires and patience will hook one of those lugs for that wicked accent ! . Doing this for 11 years and crawling AZ 1:1 dam near all my life this sport is always evolving the fun part is trying it all and finding what works best for your preference in how you crawl your rigs . So for my opinion. . Try it . . Then change it . . And on and on 🤘😎 |
Trx-4 Sport Weight Question - Similar Threads | ||||
TRX-4 Sport Roof Light Bar Question | Up'n'Over | Traxxas TRX-4 | 0 | 05-05-2019 01:10 AM |
TRX-4 Sport Servo upgrade question: endpoints | OKmon | Newbie General | 5 | 01-18-2019 10:18 AM |
Traxxas trx 4 sport vs redcat gen 7 sport part 2! | shenlonco | Scale Videos! | 0 | 08-03-2018 06:31 AM |
Traxxas trx 4 sport vs redcat gen 7 sport! | shenlonco | Scale Videos! | 0 | 07-23-2018 07:19 AM |
