04-24-2020, 01:04 PM | #1 |
Rock Crawler Join Date: Mar 2008 Location: Plainfield
| Sloppy knuckles...
I picked up a TRX-4 sport from FB market place. One of the things I've noticed is the slop where the knuckle bolts to the C on the forward axle. Is there anything I can do to tighten this up? Lou |
04-24-2020, 01:49 PM | #2 |
Newbie Join Date: Jan 2017 Location: Canada
| Re: Sloppy knuckles...
Check to make sure the bushing are installed in the top and bottom of the c-hub where the screws attach the portal to the c-hub. Sent from my iPhone using Tapatalk |
04-24-2020, 09:04 PM | #3 |
Thanks! Lou |
04-24-2020, 11:28 PM | #4 |
Well, I pulled the whole axle apart and the bushings ARE installed in the C but they are super, super sloppy. Not really sure what to try next... Lou |
04-25-2020, 07:41 AM | #5 |
If the knuckle has up/down play you can use 3x6x.1 shims to reduce the slop. If the kingpin pivot bushings flop around in the c-hubs like the c-hub bore is to large than it is time for new c-hubs. Stockers are $5. I'm partial to the Locked up steel replacements.
04-25-2020, 07:56 AM | #6 | |
| Re: Sloppy knuckles... Quote:
Lou | |
04-25-2020, 06:13 PM | #7 |
Got the stock replacements today, they were just as bad. I ended up putting a small m3 washer top and bottom of the C and that helped a ton. It still has a little play but way more tolerable. Lou |
04-28-2020, 04:06 PM | #8 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
I'm struggling to believe they have slop, mine are 2 years old and tighter than a woman's purse. Traxxas quality control is very very good usually.
04-28-2020, 04:37 PM | #9 |
If you have slop and you're not sure which part is causing it, you'd have to replace the C-hubs and the knuckles. The new Traxxas parts typically have great fit and not much slop. |
04-29-2020, 04:27 AM | #10 |
Rock Crawler Join Date: Mar 2019 Location: Terrassa
Igus bushings https://www.igus.com/product/64 |
Sloppy knuckles... - Similar Threads | ||||
Sloppy TF2 knuckles/front end? | skybolt | RC4WD Trail Finder 2 | 1 | 11-17-2017 12:08 AM |
Sloppy Knuckles | The_Madness | Losi Mini-Rock Crawler | 3 | 10-02-2010 10:49 AM |
rc4wd possible fix for sloppy knuckles | punkuup5150 | RC4WD Bully | 12 | 08-17-2009 11:49 PM |
sloppy | LEROY | Axial AX-10 Scorpion | 3 | 12-26-2008 05:47 PM |
