04-27-2020, 12:51 PM | #1 |
Newbie Join Date: Oct 2016 Location: Wheeling
| Tire clearance????
So I just picked up a trx4 bronco got some axial 1.9 beadlock wheels and proline 1.9 swampers there not the xls and they rub like crazy what all can I do to help without cutting the body up would stretching them on a 2.2 rim help any since it wouldn't be as tall
04-27-2020, 01:02 PM | #2 |
Pebble Pounder Join Date: Jan 2017 Location: Brookfield
| Re: Tire clearance????
Raise the body. do you have any adjustment left on ther body posts? Sent from my SM-N950U using Tapatalk |
04-27-2020, 01:13 PM | #3 |
Ya I raised it like 2 holes and moved the bumpers out some just wondering if there was any little tricks to this rig to get some more clearance without making it to much more top heavy
04-27-2020, 01:47 PM | #4 |
What, exactly, are the tires rubbing? If you mean the body, the only thing you can do is raise it or trim it. The body has wheel wells that were only made to accept tires around the stock size of 4.6". Super Swamper XL's are 4.75" or more.
04-27-2020, 01:50 PM | #5 |
When flexing they rubbed the bumper body and inner fenders I moved the body up some and moved the bumper out now only rubs when extremely articulated but seems more top heave since moving the body up
04-28-2020, 07:17 AM | #6 | ||
| Re: Tire clearance???? Quote:
I run 1.9 XL's on my bronco with no rubbing, Zero trimming required, body is in stock position. It's a very common combo. 1.9 non XL's are 4.2, XL's are 4.75ish. Can't be running non XL 1.9 tires... as the 4.2's wouldn't rub in any way So taking a step back, I'm thinking you do at least have the XL tires. OR you have 2.2 tires in non XL which are about 5.4" which would indeed rub. Pics are worth 1000 words here. In any case, crank down on your preload collars on the shocks a bit to raise your ride height. Your truck must be sitting way low. Only thing I can think of. Last edited by OSRC; 04-28-2020 at 07:21 AM. | ||
04-28-2020, 07:38 AM | #7 | |
I didn't realize the 4.75" tires would fit without rubbing. My KLR's barely clear so I incorrectly assumed the XL's would rub. | |
04-28-2020, 10:11 AM | #8 | |
I'm thinking they are already 2.2's, non XL. WraithKrawlr, did you buy the wheels and tired New? Used? | |
04-28-2020, 11:30 AM | #9 |
| Re: Tire clearance???? |
04-29-2020, 07:19 PM | #10 |
They are 1.9 xl on 1.9 beedlock my bad I didn't think they were and I got them brand r new lol and they rub the links bumpers body I'll probably end up taking them off I did see somewhere on here where flipping the front bumper mount around did that and helped a lot but still having clearance issues
04-29-2020, 07:34 PM | #11 |
My trx4 with the boggers my buddy's blazer with some 1.9 wheels and tires Sent from my Pixel 4 XL using Tapatalk |
04-29-2020, 07:53 PM | #12 |
Rock Stacker Join Date: Jan 2018 Location: Green Bay
Those Boggers are about 5.4" tall...same height as some 2.2 tires. The Traxxas lift kit would help but those tires are just too tall to tuck under most bodies. If they're hitting your links you'll have to adjust your endpoints with your transmitter and/or get wider wheel hexes to push the wheels out. You'd have better luck with the TSL SX Super Swamper XL that people thought you were talking about...4.75" tall.
04-29-2020, 11:05 PM | #13 |
It is generally acknowledged that the stock TRX4 Canyon Trail tires are actually pretty decent performers. Going down the tall tire and lift kit route will net you a tipsy truck.
Tire clearance???? - Similar Threads | ||||
Question about tire clearance. | maverick67 | Paint and Body | 3 | 11-07-2017 07:48 PM |
Tire clearance | old man 52 | Losi Micro-Rock Crawler | 15 | 12-04-2014 09:24 PM |
Tire Clearance? | skooter | RC4WD Trail Finder 2 | 4 | 12-11-2012 04:39 PM |
tire clearance and lowering C.O.G | -BIGMAXX- | Team Losi Comp Crawler | 26 | 11-19-2011 03:21 AM |
