Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Your multi-function?
Old 05-30-2020, 05:46 PM   #1
Default Your multi-function?
What’s on your multi-function knob? Right now I’ve got mine set to adjust steering %, but I like cruise control as well. What about you guys?
NightOwlRC is offline   Reply With Quote
Old 05-31-2020, 09:25 AM   #2
Default Re: Your multi-function?
Mine's on cruise control
Gramps is offline   Reply With Quote
Old 05-31-2020, 10:02 AM   #3
I find cruise control to be the most useful, I kind of wish that feature would get integrated into other radios.
HumboldtEF is offline   Reply With Quote
Old 05-31-2020, 05:50 PM   #4
When I was using the TRX4 controller, I was using the multi-function knob for reverse. If I got into a tight spot, I could dial back reverse to reduce wheel spin. Yeah, I know trigger control does the same, but it was much easier and more controllable if I dialed back. Then I could dial it back up under normal conditions.
dungeonracer is offline   Reply With Quote
Old 06-01-2020, 12:23 AM   #5
[QUOTE=dungeonracer;6026274]When I was using the TRX4 controller, I was using the multi-function knob for reverse. If I got into a tight spot, I could dial back reverse to reduce wheel spin. Yeah, I know trigger control does the same, but it was much easier and more controllable if I dialed back. Then I could dial it back up under normal conditions.[
That’s a good idea. Reverse is a bit touchy.
Old 06-02-2020, 03:54 PM   #6
The cruise control is OK, until you use the axe system, where you set cruise and it will maintain that speed up or over anything. Even massive inclines. No adjustments. Very clever system..
crazee horse is offline   Reply With Quote
Old 06-02-2020, 05:21 PM   #7
Personally I like to be the one taking on the obstacles. Cruise control for me is just for the walk between spots.
Your multi-function? - Similar Threads
HiLift Multi Function unit problem neo Electronics 2 11-17-2007 12:15 AM
