05-23-2020, 11:54 PM | #1 |
Rock Stacker Join Date: Jan 2010 Location: US
| Defender Shocks
This is the first time I've taken off the shocks of my defender. While I try to rebuild them, I notice they bind when tighten the bottom cap. I have build a sport kit and those shocks were very smooth. It seems like the black spacer between the 2 o-rings is a bit too thick. The outer o-ring is not flush with the shock body, so when the cap is tightened, the o-rings would thighten the shock shaft causing the bind. My question is that is it the spacers are too thick or do I need to replace the o-rings?
05-24-2020, 12:13 AM | #2 | |
Quarry Creeper Join Date: Nov 2018 Location: Oakley
| Defender Shocks Quote:
I think a lot of people leave the bottom cap a 1/4 turn loose to keep the o-rings from getting too tight. That and some good oring lube. | |
05-24-2020, 12:46 AM | #3 |
| Re: Defender Shocks |
05-24-2020, 04:33 AM | #4 |
Pebble Pounder Join Date: Jan 2017 Location: Brookfield
| Re: Defender Shocks
I don't like leaving the cap loose and shouldn't be that way. I used a thinner spacer and the shocks are smooth and leak free. The original defender shock spacer is 3 x 2.75mm. I used 2mm spacer and green slime. Sent from my SM-N950U using Tapatalk |
05-25-2020, 06:44 AM | #5 |
Rock Stacker Join Date: Apr 2020 Location: Central Florida
| Re: Defender Shocks I agree with this. I went even further and sanded the spacers down to 1.75mm on my Sport Kit shocks.
05-25-2020, 06:48 AM | #6 |
| Re: Defender Shocks
It's not a bad idea to get an assortment of 3mm spacers and shims. Sent from my SM-N950U using Tapatalk |
05-25-2020, 04:08 PM | #7 |
| Re: Defender Shocks
I found some spacers and they are working fine now. I don't remember having this issue with the sport kit. I am in the process of putting the Proline C10 body on it. I am using the 12.3 wheelbase conversion kit with the fenders.
05-25-2020, 05:07 PM | #8 |
| Re: Defender Shocks
That's going to look really good. Sent from my SM-N950U using Tapatalk |
05-26-2020, 12:16 AM | #9 |
05-26-2020, 03:22 AM | #10 | |
| Re: Defender Shocks Quote:
Sent from my SM-N950U using Tapatalk | |
Defender Shocks - Similar Threads | ||||
defender 110 of rcmodelex and defender 90 of rc4wd on the rails | gionata78 | Scale Videos! | 2 | 04-15-2013 05:00 PM |
