Your multi-function? What’s on your multi-function knob? Right now I’ve got mine set to adjust steering %, but I like cruise control as well. What about you guys? |
Re: Your multi-function? Mine's on cruise control |
Re: Your multi-function? I find cruise control to be the most useful, I kind of wish that feature would get integrated into other radios. |
Re: Your multi-function? When I was using the TRX4 controller, I was using the multi-function knob for reverse. If I got into a tight spot, I could dial back reverse to reduce wheel spin. Yeah, I know trigger control does the same, but it was much easier and more controllable if I dialed back. Then I could dial it back up under normal conditions. |
Re: Your multi-function? [QUOTE=dungeonracer;6026274]When I was using the TRX4 controller, I was using the multi-function knob for reverse. If I got into a tight spot, I could dial back reverse to reduce wheel spin. Yeah, I know trigger control does the same, but it was much easier and more controllable if I dialed back. Then I could dial it back up under normal conditions.[ That’s a good idea. Reverse is a bit touchy. |
Re: Your multi-function? The cruise control is OK, until you use the axe system, where you set cruise and it will maintain that speed up or over anything. Even massive inclines. No adjustments. Very clever system.. |
Re: Your multi-function? Quote:
Personally I like to be the one taking on the obstacles. Cruise control for me is just for the walk between spots. |
