Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Traxxas XL5 ESC
Old 07-11-2020, 12:10 AM   #1
Default Traxxas XL5 ESC
For anyone running the stock traxxas speed control, or I guess this could be a question for any programmable ESC. Do you run brakes, then reverse on second press, or instant reverse with max brake when you let go of the trigger?
dabbill is offline   Reply With Quote
Old 07-11-2020, 02:05 AM   #2
I used to run mostly trail mode, just because it was a pain in the @$$ to switch. Now with the Mamba X, high gear is forward, brake, reverse and low gear is crawling mode with forward, hill hold, instant reverse.
PFongemie is offline   Reply With Quote
Old 07-11-2020, 04:58 AM   #3
Default Re: Traxxas XL5 ESC
I rub the instant reverse plus the drag brake is better in that made too.
Sent from my SM-N950U using Tapatalk
Dirt Runner is offline   Reply With Quote
Old 07-11-2020, 05:57 AM   #4
If you're trailing you probably want it set so the drag brake does not come on until you hit the throttle backwards. If you're crawling you probablywant the drag brake set.
MOguy is offline   Reply With Quote
Old 07-12-2020, 08:00 PM   #5
This stuff is programmable for a reason. Every person is different and you program the settings the way you want them. There is no correct setting, only what works best for you.
Inspector86 is offline   Reply With Quote
Traxxas XL5 ESC - Similar Threads
Traxxas XL5 esc Blankenship Electronics 2 01-24-2011 04:55 PM
Traxxas XL5 esc NU2KRAWLIN Electronics 3 04-04-2007 08:11 PM
