Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: 2s vs 3s Performance Comparison
Old 06-26-2020, 12:27 PM   #1
Default 2s vs 3s Performance Comparison
After i got my Blazer, i got annoyed that my 5yr old would always want to drive it. So a sport was "required" so we could run together (and fewer parts to repair/adjust). i have been running the Blazer with a 3s and put a 2s in the sport, to keep the kiddo from destroying things TOO quickly. well, he's been doing really well with it; not always at full throttle, is developing some good control, etc. so i decided to give him the 3s to try. I was REALLY surprised at how much better the Sport is with a 3s. And how much slower the Blazer is on 2s. With the Sport running a 2s and the Blazer with the 3s, the Sport was just a little bit faster with the Blazer in low. With the batteries swapped, the Blazer needs high gear to keep up with the Sport. The Blazer is still faster, but BARELY.
Both rigs still crawl well with either battery, but the 3s really makes EVERYTHING better.
splyn is offline   Reply With Quote
Old 06-26-2020, 04:36 PM   #2
Default Re: 2s vs 3s Performance Comparison
What specially was better with 3S?
20vmki is offline   Reply With Quote
Old 06-26-2020, 06:33 PM   #3
it was just as composed, but it had noticeably more torque, wheel speed, speed in general. the phrase "wakes it up" is the best description. the 2s needs some coffee, the 3s already had thiers.
Old 06-26-2020, 06:40 PM   #4
Okay. I got 2 2S 2200mAh for my TRX-4 Sport (I get small packs so I can share them with my 1/16 E-Revo). I didn't go with the 3S 1400 mAh because I was worried about runtime, would it be a lot less with that 3S battery?
Old 06-27-2020, 11:48 PM   #5
The sport has taller gears at the motor(pinion/spur). Low speed in the blazer is slower/higher gear reduction than the sport.
Thats why the blazer seems so slow on 2S
mass-hole is offline   Reply With Quote
Old 06-28-2020, 07:22 PM   #6
True, but the comparative speeds between the Blazer in low gear and the sport illustrates the performance differences between the 2s and 3s packs.
Old 07-02-2020, 10:07 PM   #7
i just upgraded to a mamba x and castle slate 2850kv. HOLY COW!!! low speed with 3s is now just a little bit faster than the Sport with a 3s. High gear is WAY too fast for this rig. far too tippy but straight line fun is ... well.... fun. crawling is still good, decent control. however i just received and installed my 9t pinion and indoor crawling shows a marked improvement in crawling modulation. once i have a chance to try it on some proper obstacles, ill report some more. looks like i am headed in the right direction when it comes to performance.
Old 07-02-2020, 10:16 PM   #8
snip
unlocking the diffs helps a tiny bit
HumboldtEF is offline   Reply With Quote
Old 07-03-2020, 07:30 AM   #9
I run 9/45 on my sport with similar setups to yours and really like it with 3s. (Mamba x , Trailmaster Pro 3300, Revolver 2500 and now Puller Pro v2 2700)
I setup my Mamba X pretty much verbatim to HH recommendations on his videos.
The crawler modulation and low speed control is awesome with the gearing, motors and esc set up.
I’m very very happy with my setup on the rocks.
I agree that you’re headed in the right direction.
Benp is offline   Reply With Quote
2s vs 3s Performance Comparison - Similar Threads
Looking for comparison on 1.9 SctraX10 Tires and Wheels 13 10-30-2014 08:31 AM
tranny comparison DEX HPI Wheely King 3 08-30-2011 10:28 AM
Another 1.9 comparison neillarson Tires and Wheels 11 02-16-2011 12:24 PM
Comparison ebbet Losi Mini-Rock Crawler 3 12-01-2008 10:46 AM
Comparison ebbet Duratrax Cliff Climber 4 11-29-2008 06:57 PM
