Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Battery tray mod
Old 07-05-2020, 09:26 AM   #1
Default Battery tray mod
Was just reading dr frankensyles build thread and saw his battery tray mod. I love the idea but have a question.
Am I better off with the battery as far forward as possible or as low as possible? Or otherwise, is it possible to spin the battery tray 180 degrees and have both?!
mr_alister is offline   Reply With Quote
Old 07-05-2020, 09:34 AM   #2
Default Re: Battery tray mod
On second thoughts, you can't spin it coz the tranny is in the way...
Old 07-05-2020, 09:41 AM   #3
You can cut the end or just make mounts
Sent from my SM-G986U using Tapatalk
jemelumadu2 is offline   Reply With Quote
Old 07-06-2020, 06:56 PM   #4
So I decided to try it, I figure lower by that half inch is better than further forward.
Cut out one side of the tray and it fit right in with the wires that come out of the corner of the battery filling the "gap" on the other side.
The battery dropped so low that there was now a gap between the battery and the strap that holds it in even on the lower setteing so I stuck a piece of foam onto the under side of the strap.
Very happy with how that all worked out!
Check out the photos!
Old 07-07-2020, 03:52 PM   #5
Awesome! Glad that's workin' for ya. I just use a velcro strap for the battery and eliminate the weight of their hold-down assembly up top.
jim
dr frankenstyle is offline   Reply With Quote
Battery tray mod - Similar Threads
TRX4 Battery tray mod... high plains drifter Traxxas TRX-4 4 05-02-2018 03:34 AM
Neil's 3 dollar battery tray mod. Neil2704 Vaterra Ascender 9 01-23-2018 12:45 PM
Battery for TH with large rear tray mod? drabina Vaterra Twin Hammers 4 01-04-2016 09:46 AM
ORA's Hammer - battery tray/spare tire mod offroadace Vaterra Twin Hammers 6 03-17-2013 12:23 PM
battery tray mod into a droop suspension free droopmodmrc Losi Mini-Rock Crawler 9 11-21-2009 05:23 PM
