Andy's TRX4 I've had this TRX4 Bronco on the trail for a while now and still loving it. Not really a whole lot of mods done to it, but a fair bit of tuning I guess you could say. There's a decent amount of lead I've strategectly placed around the chassis to keep that nose down and HR brass portal covers up front. Heavier oil in the shocks seems to help too. Still running the original tires. I cut them over the winter and they work even better. I've been running other tires as well, but I keep coming back to these. These pics are from Mt Cardigan in Orange New Hampshire. https://scontent-bos3-1.xx.fbcdn.net...c9&oe=5F27B00C https://scontent-bos3-1.xx.fbcdn.net...50&oe=5F2B3034 https://scontent-bos3-1.xx.fbcdn.net...b4&oe=5F283237 https://scontent-bos3-1.xx.fbcdn.net...e0&oe=5F27EE0B https://scontent-bos3-1.xx.fbcdn.net...1f&oe=5F2951E8 https://scontent-bos3-1.xx.fbcdn.net...44&oe=5F2A87EC https://scontent-bos3-1.xx.fbcdn.net...a4&oe=5F2861A7 https://scontent-bos3-1.xx.fbcdn.net...86&oe=5F2A4335 |
Re: Andy's TRX4 With all that we do to these rigs, it's nice to see a thoroughly scraped-up mostly stock TRX4... just out there gettin' it done. I think that some of us get a little overwhelmed ( and lost) with all the mods and upgrades. Glad that you're enjoying your rig. Appears that she climbs like a beast and looks like an awesome/ scenic location! |
Re: Andy's TRX4 My original esc did last year and a SV3 I had picked up used replaced that, but it died too. There's a HH BRXL in there now so I think that one will last (it better!). Still running a stock motor but that will change after this one (I've gone through 3, the 1st lasted a long time, but the replacements... not so much). So originally I had a lot of lead on the underside of the front tray, and more at the front of each running board. I was running a full sized 3S in the stock tray, but switched to a shorty in the front tray. This worked well (front tray) but if the truck started to tip at all ... with all the weight up front and that battery up high ... ummm yeah...I changed things up. I pulled the side/front weight and made a lead cross member of sorts right over the front axle and moved the shorty to the stock tray. I tried it all the way forward, as well as on it's side in the rear well of the tray. both worked well and improved side and down-hilling a lot, but the forward tray position seems to do the best if steep climbs are involved (and they usually are). https://scontent-bos3-1.xx.fbcdn.net...d3&oe=5F29BE91 The stuff wrapped in black tape is all the 1/4 oz stick-on lead I used. https://scontent-bos3-1.xx.fbcdn.net...fb&oe=5F2AAEAE https://scontent-bos3-1.xx.fbcdn.net...89&oe=5F2A9D19 https://scontent-bos3-1.xx.fbcdn.net...3c&oe=5F2AB0A0 https://scontent-bos3-1.xx.fbcdn.net...28&oe=5F2A0842 https://scontent-bos3-1.xx.fbcdn.net...ff&oe=5F2849BF |
Re: Andy's TRX4 Looking good! |
Re: Andy's TRX4 Quote:
One of my other sets of tires. RC4WD Iroks that I've been braking in. I recently cut them (middle tread) and shaved them (they were getting feathered) and it's helped a lot. I have a jig a made for a drill and spin them in the opposite direction they would go on the truck and work them over with a file (like you would with a wood lathe). I always like to put a little back-cut on the tread of a directional tire so they bite harder. https://scontent-bos3-1.xx.fbcdn.net...9a&oe=5F280C82 |
