08-18-2020, 07:51 AM | #41 |
Newbie Join Date: Dec 2015 Location: Central Ohio
| Re: Ugh, servos are so expensive
So I run a 23kg blue PowerHD in my Kraton with a Castle BEC @ 7.4v and she's lasted for a few years. I think one of the challenges with the crawlers is that there is no servo saver, so there is nothing to "give" anywhere. Ideally you probably want a servo with really hard and durable gearsets. Budget servo's on ESC internal BEC's all suck, and if you are running factory XL5 electronics, that kind of power draw can roast your ESC.
08-18-2020, 08:07 AM | #42 |
Rock Crawler Join Date: Apr 2020 Location: Northern MN
Forgive my ignorance, but what is a “servo saver?” I saw mentioned a few up that the plastic gear in one of the servos above can act as an internal one. Is it just a mechanism attached to the servo that will break instead of the servo? ETA - just looked them up and kind of get the drift. Are there different types? Last edited by Benp; 08-18-2020 at 08:10 AM. |
08-18-2020, 08:36 AM | #43 | |
| Re: Ugh, servos are so expensive Quote:
08-18-2020, 08:53 AM | #44 | |
Thanks!! I didn’t realize it was a common item on non crawler vehicles. | |
08-18-2020, 08:58 PM | #45 |
Quarry Creeper Join Date: May 2020 Location: Canada
Here is a couple (bad) photos of servo savers. One from my 2wd stampede and one from my 4wd slash. The stampede one is really basic and gets installed on the servo spline instead of a horn. The slash one is more complicated but you can kinda see the springs and whatnot. |
08-19-2020, 05:07 AM | #46 |
Ok! That makes sense. |
08-20-2020, 10:20 AM | #47 |
You can spend a little on a budget servo and replace it several times when it fails, or you can pay a little more for a quality servo and only buy it once. Ultimately, you will spend less in the long run on a quality servo.
08-20-2020, 11:33 AM | #48 |
Rock Crawler Join Date: Apr 2008 Location: pittsburgh
That depends. I've rarely had anything but stock servos fail. If I get 5 years out of a savox 0251 for 30$ in a trail trail truck, and it's still going, how is buying an 80$ servo saving money? I do understand I would get more power for the extra 50$. If you need an extra strong servo for competition I get it, but the average basher really doesn't require it... Sent from my moto e5 cruise using Tapatalk |
08-20-2020, 08:09 PM | #49 |
I look at this way. If i had 100 bucks to spare id probably buy a kick ass servo. But i rarely have a 100 bucks to spare. So the only way i get a 100 dollar servo is if my cheap one dies at a time when i have 100 bucks to spare |
09-30-2020, 01:35 PM | #50 |
RCC Addict Join Date: Feb 2012 Location: UK
Savox SW1210SG & Savox 1256TG here...both five years old and been in wet conditions. They are both still going strong. :-) Not super expensive... especially when you divide the cost over the years.
09-30-2020, 06:26 PM | #51 |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
If you ever need another one, I have the ECOPOWER WP120T for $70 USD and it is great! has around 400oz at 7.4v! Sent from my iPad using Tapatalk Last edited by ScaleLifeNewbie; 09-30-2020 at 06:29 PM. |
10-01-2020, 12:49 AM | #52 |
Pebble Pounder Join Date: Sep 2014 Location: Canada
As the above comments. Don’t waste your money on the cheaper servos like those you mentioned, you’ll go thru enough of those to spend more $ than you would have on a solid one in the first place. I run a Savox 1210 SG on mine at 7.4V, has more than enough torque. Waterproof. Runs about $110 CAD. Sent from my iPhone using Tapatalk |
10-01-2020, 01:38 AM | #53 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
I spent money for a decent servo once, a Hitec 7955TG and it was miles better than the cheapo stuff of the same specs, but still burned out after a couple of years. Most of my buddies run cheap DS and JX and whatever 20kg servos, I have one too, and we never had one fail. They are overrated in the specs but for the money they're good. I can get 5 of those instead of one "big name" servo. Where was I going with this... dunno. |
10-01-2020, 03:38 AM | #54 |
Rock Crawler Join Date: Mar 2019 Location: Terrassa
| Re: Ugh, servos are so expensive |
10-01-2020, 05:38 AM | #55 |
Quarry Creeper Join Date: Jun 2015 Location: France
Have around 10 trucks, my servos budget ranges from $15 to $30 ... trailing, rock-crawling, bashing, running underwater, never had one failing ... so feel no need for 10 $100 servos and saves me from tar and feathers |
10-01-2020, 11:20 AM | #56 |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
| Re: Ugh, servos are so expensive I am running 4 Savox Servos, 1212, 1256 and 2 1230S. When I used my TRX4 controller the ones I had in that truck were loader and always looking for center. They would also heat up and have end point issues. I dumped the TRX controller and now use a DX5 rugged and no more heat, no more centering issues and no louder than other servos. The Savox servos were also controlled by a couple other Spectrum controller, a DX5c and one of there cheap ones and they are not loud and perform just fine. I think that many issues people have with servos has allot to do with their controllers and receivers. Changing to a decent controller made a huge difference for me. |
10-01-2020, 01:24 PM | #57 |
Ugh, servos are so expensive - Similar Threads | ||||
Ugh! | despain85 | Axial Wraith | 2 | 04-28-2012 09:51 PM |
Ugh, I'm addicted | Rjohn929 | 1.9 Scale Rigs | 3 | 11-04-2009 09:56 AM |
Ugh | JasonInAugusta | Chit Chat | 31 | 11-29-2007 08:43 PM |
Ugh! | CoreyK | General Scale Talk | 6 | 06-10-2006 05:14 PM |
