Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Trx4 must have brass
Old 08-19-2020, 07:00 PM   #1
Default Trx4 must have brass
I’ve been modifying my rig and I’m going to start adding weight. Which brass pieces give you the best bang for your buck?
Bobcapo is offline   Reply With Quote
Old 08-19-2020, 07:08 PM   #2
Default Re: Trx4 must have brass
Havent bought any brass except an Amazon front bumper mount (93g), i didnt end up using it cuz even after drilling holes in the frame bigger, when u flipped the brass mount, it wouldn't let you put screws through.
I started with aluminum beadlock wheels, and they are already significantly heavier than stock, then i put roughly 3oz stick-on 1:1 wheel weights on the inside of wheels, wrapped em in electrical tape, and now each wheel has (as stated) approx. 3-3.25oz lead weight inside an ALREADY heavier wheel. HUGE improvement!
Aluminum front bumper helped a LOT, too!! Let me know what works for you when u decide to shell out that brass dough!
Sent from my Pixel 3a using Tapatalk
23drumerboy is offline   Reply With Quote
Old 08-20-2020, 08:53 AM   #3
The only weight I've added to my TRX4 & TRX6 was brass portal covers. The TRX4 also has steel beadlock wheels
Gramps is online now   Reply With Quote
Old 08-20-2020, 07:39 PM   #4
I’m thinking about the brass portal covers and maybe the diff covers
Old 08-20-2020, 07:46 PM   #5
Knuckles (or portal covers in this case) are usually the best bang for the buck on any crawler since you can add all the weight you should ever need with them though the TRX4 can be a fat pig so your mileage may vary.
Avoid adding brass in places that are sprung (sprung weight) like bumpers as they hinder performance a lot more that if its unsprung weight (weight on the axle or anywhere thats not held up by the springs)
I'll also add you can add too much weight, only add as much as you need to alter the F/R balance to your liking then stop lol
HumboldtEF is offline   Reply With Quote
Old 08-20-2020, 07:55 PM   #6
In general you want un-sprung weight. I have 5 TRX4s and all are running one form or another of portal weights. I really like the SSD portal weights. I have not been a fan of the brass diff covers because they look nice when new but look like crap in pretty short order as they get all scratched up. In general, any additional sprung weight on the chassis is counter productive but is also a personal choice depending on the individual.
Inspector86 is offline   Reply With Quote
Old 08-26-2020, 01:09 PM   #7
There is no one perfect answer.Depends on our rig, and what type of driving you do.
The weight of your vehicle plays into it. How the weigh is distributed. If you like higher speed trailing or lower speed crawling, what tires, what foams, How much over drive...
MOguy is offline   Reply With Quote
Old 09-01-2020, 01:43 AM   #8
I'm replacing front and rear axles on the Bronco with Aluminum for grins, and then adding the SSD-RC portal brass weights. They haven't been installed yet, but fitting them up, they are pretty excellent quality bits, tight fitment, excellent finish.
FWIW
Merovean is offline   Reply With Quote
Old 09-01-2020, 06:52 PM   #9
I am working on my first build in decades. I have the TRX-4 Defender and it is super top heavy. It came stock with the pre-glued plastic wheels and that just made the balance worse. I ditched the wheel/tire combo for a set of aluminum bead locks and added brass bolt in wheel weights on each corner. I did add the brass diff covers but I am cool if they get beat up. (They were cheap). These couple of things added a significant amount of unsprung weight and allowed me to stiffen the suspension quite a bit. The truck will always be a little top heavy but just that little bit of brass made a huge difference in performance when side hilling. It still needs some tuning to counter steeper climbing issues to keep the front end down but that is a whole different can of fish!
ExoSphere64 is offline   Reply With Quote
Old 09-02-2020, 07:45 AM   #10
Moderator
JatoTheRipper's Avatar
SSD portal weights and they are great.
Old 09-07-2020, 04:43 AM   #11
Yeah they really are. Alongside some LockedupRC Steel Knuckles I've been really impressed with the quality.
Behind some alloy wheels the SSD Portal covers look great, not quite Brakes, but sorta scale.
Old 09-07-2020, 02:41 PM   #12
I have a 97g brass front bumper weight off Amazon for like 10 bucks. I added about 45g
of sticky weight on it. It’s not the prettiest, but it performs. only downfall is you can’t flip it upside down because the screws for some odd reason don’t go in. I also have a Metal front bumper off Amazon with 90g of weight stuffed in it also. I again, not the prettiest way of doing it, but it preforms a lot better.
ScaleLifeNewbie is offline   Reply With Quote
Old 09-08-2020, 12:08 AM   #13
SSD portal weights front and rear for me, and its been great
Sent from my SM-G981U using Tapatalk
vasdimpop is offline   Reply With Quote
Old 09-08-2020, 10:40 AM   #14
Not sure if you are still following this
Adding more and more weight is not the best way to make things handle better. Some weight is needed but there other ways you can improve things.
Lower your center of gravity, add width, overdrive,
Old 09-10-2020, 01:38 AM   #15
This true, but adding brass lowers the center of gravity more than anything else you can do to the truck. I got cheap Treal copy brass portal, c hub, and cheap Amazon heavy diff covers. Those little things made my trx4 crawl easier and made it more stable. I have desert lizard 100mm shocks set up for max droop with a little more height.
As far as width goes my heavy trx4 sport can crawl better than my capra. Ill add that the capra needs 2.2 scale tires to take advantage of the width. Capra is an annoying belly dragger.
CNCist is offline   Reply With Quote
Old 09-14-2020, 01:57 PM   #16
If you want the nice body and other addons you have to add a lot more the weight and if you are not comping then width isn't as much of an issue and width can really help. Overdrive works wonders. I am less than 8lbs, run about 4 oz of weight in each front tire and a brass dif cover. I run 24% OD.
AND
Capras are way overrated!!
Old 09-28-2020, 08:03 PM   #17
I put brass portal housing and knuckles. Need to do the rear portal boxes. It has helped. I need to move more weight around on the chassis!
size does matter is offline   Reply With Quote
Old 09-28-2020, 11:49 PM   #18
Remove weight from rear.
Remove the stock battery tray.
Adding weight is bad for performance.
Egsise is offline   Reply With Quote
Old 09-29-2020, 01:28 PM   #19
Unless you put it in the right spots.
Old 10-02-2020, 10:51 PM   #20
Brass portal gearbox housings are your best bet. Anywhere else -- anywhere else -- that you can put extra weight will be higher-up than the portal gearbox housings, and thus will not lower the center of gravity as much. Brass bumper weights, in particular, actually raise the center of gravity -- they're too high up. A brass bumper weight in the front only might help with achieving a forward weight bias, but don't bother trying to improve the weight bias until you've gotten the rollover problem solved.
fyrstormer is offline   Reply With Quote
Trx4 must have brass - Similar Threads
TRX4 Sport body on TRX4 Crawler kit chassisc redpeppers Paint and Body 7 09-14-2019 12:59 AM
Hot Racing Brass Knuckles and SSD Brass Weights compatibility saddlesore Axial SCX10 II 5 07-15-2017 04:27 PM
