09-08-2020, 03:19 PM | #21 |
| Re: 3d printed differentials
There will be a balance problem here, were the weight of your packs will slow you down, and going to a pack with less voltage will actually make you faster because of the weight you save. Also, in a straight line a 12S pack will be fine, but on a road course, you'll like run into issue. Also, the tuning is all wrong on solid axles for road use, it will be a hard row to how to get suspension performance on the track that comes anywhere close to a touring car. But, it will be interesting to see what you come up with. Back to the diffs…. First, in the world of RC, when people start putting on ridiculous power, 4S +, they convert their spur over to metal, because the nylon spurs just can't handle the extra stress. It seems like in this process, you'll be bucking that trend. Second, I do not believe you will easily meet the required tolerances with an FDM printer, it will likely require a resin printer, and neither will get you close to what your after in a sub-$10k printer. |
09-08-2020, 03:39 PM | #22 | |
Pebble Pounder Join Date: May 2020 Location: US
| Re: 3d printed differentials Quote:
Lastly the diffs im going to make the gear teeth very thick and coat it in line x or go with a ball diff most likely test both. Sent from my SM-G986U using Tapatalk | |
09-09-2020, 08:01 AM | #23 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
| Re: 3d printed differentials |
09-09-2020, 08:44 AM | #24 |
09-09-2020, 09:53 AM | #25 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
While I fully encourage experimentation and innovation I also hate to see people waste their time and energy. I don't have a ton of time to sit here typing so excuse the brevity of post. 3D printed plastics will absolutely not work for a 1/10 scale differential. As you're likely already aware nylon would be your best bet but even that wouldn't be adequate. There's at least 2 major issues that come to mind right away - strength & heat. Plastic isn't strong enough to support gear teeth at the loads you're going to be throwing at them and there's no way the output shaft will endure that kind of torque. I'd honestly be shocked if it went 1meter before if imploded. And heat, at the speeds you're talking about there's going to be so much friction in the diff that plastic gears would probably melt. And that's all after you've spent hours and hours on perfecting the design and refining it to be within the tolerances of what might actually work. The advantage that Porsche has over you is size. The bigger parts are the stronger they are and the more heat they can tolerate. Oh yeah, and millions of dollars as well as the best engineers in the business. Again, not trying to shit on your idea, but I think you'd be better off looking at other methods of reducing weight. Also consider that even if you did somehow miraculously make this work you're going to save a minimal amount of weight, I wouldn't be surprised if was only a savings of 20-30grams or less. Is 25grams worth the hours and hours of tedious design work? |
09-09-2020, 11:31 AM | #26 |
I saw the new Cen F450 and thought of this thread, you're worried about weight and this thing is actaully listed a 5.5 lbs which is damn light. Seems like that could potentially be turned into something that may work with its open diffs and sway bars or atleast be fun while still being silly.
09-09-2020, 12:28 PM | #27 | |
09-09-2020, 12:37 PM | #28 | |
09-09-2020, 01:03 PM | #29 | |
230C isn't that hot for filaments, in fact, it is right in the comfort zone for most of the common ones, including PLA, PETG, and ABS.... the exact ones that absolutely will not withstand the stress of 3S power, to say nothing about 12S. How will coating the gears with bed liner help? That is not a smooth coating, it will increase weight, cause a lot more friction, and screw up the gear tolerances. If anything, they should be coated with a thin high temp polymer or ceramic coating. I am very impress with the fine detail my printer can print, but, FDM has its limits. The print orientation will be key, to get the most strength out of the gear you'll have to print it vertical, or at a 45* angle, printing them flat will put the layers in line with the direction of stress, which makes for a weak part. | |
09-09-2020, 01:39 PM | #30 | |
09-09-2020, 08:09 PM | #31 |
I'm out... Recommendations requested, recommendations received, it is up to you to process the advice you have requested and proceed accordingly.
09-09-2020, 08:10 PM | #32 |
09-10-2020, 02:58 AM | #33 |
Newbie Join Date: Apr 2020 Location: San diego
I know I'm harping on a beaten thread here. If you dont feel like reading a semi-rant, shear strength is the problem not heat. Make the gears big. No plastic known to man will hold up as a differential, i know it was said porche 3d printed pistons, but thats rough metal with a final CNC portion to the process. Heat in the plastic isn't the big problem, it's shear strength. If heat was a problem in a diff then carbon ceramic gears would be a thing. Keep in mind real diffs have oil to cool them down, we only have some grease, and grease doesn't add much benefits to cooling. Its plastic, definition of plastic is that its maleable. It is POSSIBLE, the density, and size you would have to make it would defeat the purpose. So ill leave on that note, work around shear strength of the material you would use and design around that. |
10-24-2020, 02:31 AM | #34 |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
Here to resurrect an old thread! How’d it go? Did the printed gears work? Sent from my iPad using Tapatalk |
12-18-2020, 03:19 AM | #35 |
Just reading this, but if you want to shave some weight I would just run one motor. A larger BLDC outrunner will produce more power with less weight. Team Brood make some long outrunners that should have crazy power density. or Just a larger sensored motor. I am not aware of any reason why a dual motor setup would ever perform better except for independently modulating axle speeds. |
12-18-2020, 12:39 PM | #36 | |
I get the idea of doing something different to prove a point. This is a big reason I turned a Slash into track thoroughbred. It was awesome to see the Ofna, Losi and AE drivers' faces when they found out their race-bred SCT just got beat by a Slash. But, honestly, if I raced SCTs again, I would just buy one of the race-bred trucks, it would save a lot in both money and time. But, something tells me that a solid axle portalled 6x6 will be hard pressed to even get near the performance of an on-road factory racer. I could be wrong, but I doubt it.... | |
12-22-2020, 09:50 AM | #37 | |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
If you want to lower your center of gravity you need to shed every single once you can ABOVE the axles. You don't need allot of weight in your axles if you shed every single ounce you can above them but you still need weight in the axles. Last edited by MOguy; 12-22-2020 at 09:53 AM. | |
12-22-2020, 09:51 AM | #38 | |
12-22-2020, 10:16 AM | #39 |
| Re: 3d printed differentials Proof? I mean, its rare, but I do miss the mark from time to time. This whole thread seems like you REALLY wanted us to agree with you about the printed diffs, but none of us have. To put it bluntly, this is the point where you need to put up or shut up; lets see some video of this TRX6 spanking on road sedans. |
12-22-2020, 11:51 AM | #40 |
RCC Addict Join Date: Aug 2013 Location: Calgary - in the Great White North
Not sure about 12s but these guys 3d print the whole truck (except tires). So someone's doing it. Give it a try and report back. It's those that think outside the box that push development. There's also lots of failures to learn from along the way.
3d printed differentials - Similar Threads | ||||
Differentials | jeeptec | Axial SCX-10 | 5 | 05-23-2017 01:24 PM |
MRC Differentials? | Blazerbogger | Losi Mini-Rock Crawler | 6 | 02-25-2015 11:28 AM |
waterproofing differentials | rick_c | Tools, and Procedures | 7 | 02-02-2011 08:01 PM |
Why locking the differentials? | kc092755 | Newbie General | 7 | 08-30-2009 10:46 AM |
