Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: ScaleLifeNewbie’s TRX4 build
Old 10-11-2020, 05:55 PM   #101
Default Re: ScaleLifeNewbie’s TRX4 build
Originally Posted by ScaleLifeNewbie View Post
I completely took the shock towers off so it’s completely flat from the battery tray back. There’s a picture a few replies up if you want to see it
Ah. I totally glazed over that detail.
Looks good!
Benp is offline   Reply With Quote
Old 10-11-2020, 06:26 PM   #102
It’s all good Benp!
Cura says 1 day 2hrs to print. I want a good quality, so I’m going to let it takes its time.
ScaleLifeNewbie is offline   Reply With Quote
Old 10-12-2020, 12:09 AM   #103
Well, I was having a problem with the drive gear on the printer, but I got it sorted out and now printing bed!
Old 10-12-2020, 07:06 PM   #104
Anybody got ideas on how I can mount the cab to the chassis? Without rear body posts, it won’t stay level.
Old 10-12-2020, 07:25 PM   #105
Default ScaleLifeNewbie’s TRX4 build
Prototype #1.
Adjustments needed:
Needs to be wider
Follow body lines better
Smaller back window.
Old 10-12-2020, 11:02 PM   #106
I’d glue a magnet to that lowest body line where it dips in facing down and make an angled steel bracket coming off the frame for it to sit on
austin-92 is offline   Reply With Quote
Old 10-12-2020, 11:05 PM   #107
That’s a great idea! I’m going to try n see if the cab wall that I’m printing will hold itself, if not I’ll definitely be doing this
Old 10-13-2020, 03:25 AM   #108
Glad I could help, good luck
Old 10-13-2020, 08:49 PM   #109
Well, now that my printer is sorted out, time to make some design tweaks to the flatbed and do a print!
Old 10-13-2020, 09:49 PM   #110
I just realized that the stock battery location won’t work with this bed without a bump out on the bed itself. I’m going to do this and see how it looks.
Old 10-14-2020, 01:35 AM   #111
Going to continue working on bed tomorrow, plan is to turn the bump out into a fuel tank. Sorry for the lack of pics, will be more soon!
Old 10-16-2020, 03:11 AM   #112
I honestly can’t make up my mind. I’m going back and forth between a flatbed and cage. I think a cage would make more since because it’s tuned for crawling with having the fenders cut out, super crazy articulation, etc. I think I’m going to save the flatbed for another body. I want to do a hardbody without rust holes, dents and dings.
Old 10-17-2020, 07:16 PM   #113
Sorry for the lack of content, I’m having a lot of problems with my printer. Once there are sorted out, I’ll be back on here more
ScaleLifeNewbie’s TRX4 build - Similar Threads
Trx4 Sport build Shawns303 Traxxas TRX-4 15 01-12-2020 08:41 PM
TRX4 LC70 Build Brian5582 1.9 Scale Rigs 41 08-25-2019 08:02 AM
Trx4 blazer build trex4Owner Traxxas TRX-4 10 11-20-2018 09:42 AM
underscorepatrick ‘s FJ trx4 build : underscorepatrick Traxxas TRX-4 27 09-28-2018 02:26 AM
pmis's trx4 build pourMoneyIntoSea Traxxas TRX-4 6 05-12-2018 07:12 AM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
