Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: ScaleLifeNewbie’s TRX4 build
Old 09-07-2020, 09:27 PM   #1
Default ScaleLifeNewbie’s TRX4 build
Hey everyone, this thread will be regarding my TRX4 Bronco build. Unfortunately I only have recent pics, but we’ll make it work!
ScaleLifeNewbie is online now   Reply With Quote
Old 09-07-2020, 09:28 PM   #2
Default Re: ScaleLifeNewbie’s TRX4 build
That looks good whats the specs?
Sent from my SM-G986U using Tapatalk
jemelumadu2 is offline   Reply With Quote
Old 09-07-2020, 09:29 PM   #3
Let’s start off with the current electronics that are in it now.
RC4WD 45t with dual fans
XL-5hv
Factory H/L gear servo
Factory diff servos
EcoPower WP120T servo on the way paired with metal horn
Old 09-07-2020, 09:31 PM   #4
Now the performance/cosmetic mods
97g brass front bumper mount with an extra 45g of weight and a metal front bumper with 65g of weight inside adding up to 207g
Metal rear bumper
2.2s Super Swampers
ESS DUAL+ Soundkit
Jeep body and modded Bronco body
Yeah racing roof rack
Spare tire mount
Antenna w/ flag
Scale accessories including jack, sand ladders, canoe, DIY fishing pole, and some smaller stuff.
A LOT of stickers, you can never go wrong with stickers!
Old 09-07-2020, 09:34 PM   #5
Also, I have my rear shocks relocated to another hole that also holds the plastic sides on. Although I’m not too happy with the ride height, it does flex more.
Where it sits:
Where I want it to sit:
Old 09-07-2020, 09:44 PM   #6
Now onto my custom built trailer.
Box of the trailer:
1/2” thick plywood bottom
Shims hot glued on for the sides
The small marker lights on the chrome off the Bronco body for taillights/marker lights.
Axle:
The plastic part on the factory rock sliders where it screws on the TRX4
All thread rod for the axle
2 washers, 6 nuts, and 2 wood screws to mount the axle.
Hitch on trailer:
Extra link from when I changed wheelbase on trx4
Staples/hot glue (not the strongest, but will work until I think of another idea)
Hitch on the truck:
Wooden dowel rod painted black
Another plastic part off the TRXr rock sliders
A spare nut/bolt
2 small screws
And for anyone curious, the whole trailer setup costed around $40.
Old 09-07-2020, 09:53 PM   #7
And now, probably my favorite body, the bronco body. It started out as this beautiful Sunset edition body, but then I decided to change it up a little bit. I started by just removing the Sunset stickers and it went from there. It now looks like this.
It’s amazing what a heat gun and some imagination can do.
Old 09-07-2020, 09:55 PM   #8
Anybody got any ideas on how I can mount my hood stack to the body? I tired hot gluing and it came right off on the first of many flips. It’s a steel pipe and it’s hollow all they way through.
Old 09-07-2020, 10:16 PM   #9
Figured I’d add how I painted my Jeep body. I live in Hawaii and there are ZERO hobby stores within 100 miles of me, and you can’t get spray paints shipped here. So, I was on the fence about even getting a body because I didn’t want it to flake off super easy. Well, I can tell you one thing, I must’ve done something right, because it isn’t flaking off ANYWHERE, not even on the spots I painted on the outside!
Here’s the paint I used:
I did 5-6 coats of the red, then backed with flat black to get a deep maroon color. The maroon is a lot more visible on person than on a camera. I then masked off the entire outside of the body except the fenders, grille, running boards, “removable top”, tailgate, door handles and door hinges. I did the whole tailgate black because I messed up, but it looks okay. I did the black on the outside to get a matte look and rough feel like it is on a 1:1 Jeep
You can see where I did flat black on the outside and where I didn’t. Id say it looks good for NAPA auto parts paint.
Old 09-07-2020, 10:19 PM   #10
Also did my diff covers red to match the beadlocks on the wheels. It kind of matches, but not 100% accurate.
Old 09-07-2020, 10:22 PM   #11
The tires I have on are $65 on Amazon for a set of 5. They are true beadlocks, so I was able to take my foams out. The wheels are plastic, may throw some metal beadlocks on later.
Old 09-08-2020, 03:34 PM   #12
It gets crazy flex with rear shocks moved. I’m going to leave them for now, I’d rather it preform better than look better.
Old 09-08-2020, 11:46 PM   #13
Thats a lot of articulation! Wow.
HugoBiermann is online now   Reply With Quote
Old 09-09-2020, 12:54 AM   #14
Well..no offense but "articulation " is overrated ;)
Imagine your wheels dropping in every rock hole ...thats really not what you want.
http://rctruckstop.com/2014/02/10/co...etup-mistakes/
themountain is online now   Reply With Quote
Old 09-09-2020, 01:42 AM   #15
Yeah, it definitely is.
Old 09-09-2020, 01:43 AM   #16
Common Scaler Crawler Setup Mistakes - RC TRUCK STOP
You make a good point with that.
also, I’ve heard with this setup it will want to tip back easier while climbing a hill.
When my servo gets here I’ll run it and I’ll post my thoughts on it.
Old 09-09-2020, 06:07 AM   #17
I don't have anything to say about it... its great
Old 09-09-2020, 12:35 PM   #18
Heck yeah. I like it!
I’d put it through it’s paces how it is before reverting back.
That way you at least know.
Benp is online now   Reply With Quote
Old 09-09-2020, 02:52 PM   #19
Yeah, for sure. My servo should be here tomorrow and I’ll have an insight on that too.
Old 09-09-2020, 02:53 PM   #20
Thank you! I’ve put a lot of time/money into it
ScaleLifeNewbie’s TRX4 build - Similar Threads
Trx4 Sport build Shawns303 Traxxas TRX-4 15 01-12-2020 08:41 PM
TRX4 LC70 Build Brian5582 1.9 Scale Rigs 41 08-25-2019 08:02 AM
Trx4 blazer build trex4Owner Traxxas TRX-4 10 11-20-2018 09:42 AM
underscorepatrick ‘s FJ trx4 build : underscorepatrick Traxxas TRX-4 27 09-28-2018 02:26 AM
pmis's trx4 build pourMoneyIntoSea Traxxas TRX-4 6 05-12-2018 07:12 AM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
