Active suspension trx6/4 Hey guys I have an idea for active suspension to complete my race trx6 and i need help with the servo burning out or being too stiff thoughts? Active suspension scx10 https://youtu.be/9ynjglfqH04https://uploads.tapatalk-cdn.com/202...c7a86b151f.jpg Sent from my SM-G986U using Tapatalk |
Active suspension trx6/4 That looks cool. To keep from burning out I would start by moving the servo so its pivot point is vertically aligned with your shock mount on the axle. And have the servo arm running parallel to the shock. This would position the servo to take an axial load vs a rotational( ie torque) loading. Idk just my thoughts Sent from my iPhone using Tapatalk |
Re: Active suspension trx6/4 Quote:
Re: Active suspension trx6/4 I dont know what servo you have but basic low budget servos often lack overload protections. When a servo is loaded up it can have a runaway situation where the amperage (I may be mixing this part up) increases, the servo gets hotter, the hotter it gets the more amperage it draws and on and on until the magic smoke is let out. John Ron Holmes explained this once in a much more accurate way. But to summarize cheap servos lack overload protection where as most nice servos (read more expensive) do have this protection built in. I've done this myself by parking a rig on flat ground, leaving it on with a tiny load on the servo, came back 10-15 minutes later and the servo would no longer respond. Also make sure your end points are good. EDIT: what did you mean by the servo being too stiff? |
Re: Active suspension trx6/4 This would be absolutely epic for side hilling, climbing, descending. Great idea. |
Re: Active suspension trx6/4 I love the idea and think it could have some practical applications. One concern I would have is raising the cg with the added servo weight is probably going to negate the benefits. Then my brain starting pondering how you could get that servo weight down low. How about a cantilever setup? Have the servos down low near the tranny. Have the cantilever arm placed near the existing shock mount. Servo connects to the cantilever via a link. With the cantilever you can make the lever arms different lengths. For example, if the side that connects to the servo is longer you could actually go with a lower torque servo. I was also thinking in this setup you could use springs attached to the servo arm as helpers to reduce the tension on the servo if you have a default ride height. |
I was just visualizing other configuration options. |
