10-02-2020, 02:53 PM | #1 |
Newbie Join Date: Jul 2020 Location: Manor Lakes
| Motor not running
There seems to be a problem with the motor, I took the TRX4 Defender to the beach and had it literally swimming when it stopped all of a sudden. The steering servo still works but there is no throttle. Any idea on what is the problem. See video for details: http://www.youtube.com/shorts/kaTGJO2HF3E Sent from my iPhone using Tapatalk |
10-02-2020, 03:13 PM | #2 | |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
| Motor not running Quote:
If you went swimming, it probably took on too much water locked up. Take it off the spur gear and see if it spins. Could be the spur gear locked up. Sent from my iPad using Tapatalk Last edited by ScaleLifeNewbie; 10-02-2020 at 03:30 PM. | |
10-02-2020, 03:17 PM | #3 |
Pebble Pounder Join Date: Jan 2017 Location: Brookfield
| Re: Motor not running
Will the motor spin by hand. Your getting signals on the esc lights so the rest of the electronics seen seem ok. Sent from my SM-N950U using Tapatalk |
10-02-2020, 03:20 PM | #4 | |
| Re: Motor not running Quote:
I tried that and it does spin, but might give it another try else time for new motor? Sent from my iPhone using Tapatalk | |
10-02-2020, 03:26 PM | #5 |
Take some leads and test it direct to see if it will run. You'll know then for sure Sent from my SM-N950U using Tapatalk |
10-02-2020, 03:35 PM | #6 |
Newbie Join Date: Jul 2020 Location: US
Trx4 manual is pretty adamant about keeping the rig out of salt water; electronics and salt water don't mix very well Sent from my SM-G981U using Tapatalk |
10-02-2020, 03:36 PM | #7 |
| Re: Motor not running |
10-02-2020, 04:09 PM | #8 | |
Sent from my SM-N950U using Tapatalk | |
10-02-2020, 06:35 PM | #9 |
It might be stuck brushes, give it some throttle and push the truck. If it starts to work again you know you had stuck brushes (and the motor needs cleaning). Also on the subject of waterproof electronics if you read the fine print you'll see what this really means is its splash proof and not intended to be submerged. Submarine proof electronics are extremely rare (all I can think of is a single servo) Last edited by HumboldtEF; 10-02-2020 at 06:38 PM. |
10-02-2020, 08:58 PM | #10 |
It’s working now, thanks guys. I have it a nice turn and it started again. Sent from my iPhone using Tapatalk |
10-02-2020, 10:26 PM | #11 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
Wait. You started a thread asking for help with a motor that doesn't work, and you didn't even rotate the motor by hand first? That is the simplest troubleshooting step you could possibly do. Just roll the truck along the ground for a few inches and the motor will rotate several times. Stop running your truck in saltwater. Saltwater is bad for every single component of the truck -- it even weakens plastic over time. There's a reason oceangoing ships have to be constructed from special salt-resistant materials, and it's not because the people who buy those boats want to spend extra money. You will destroy your truck if you keep running it in saltwater -- it's only a matter of how long your luck holds-out. |
10-02-2020, 10:46 PM | #12 | |
Well said completely 100% true Sent from my iPad using Tapatalk | |
10-02-2020, 10:55 PM | #13 |
I'd say if anyone knows what saltwater does to manufactured items, it would be someone who lives on Hawai'i.
10-02-2020, 11:36 PM | #14 |
Motor not running - Similar Threads | ||||
What motor you running? | ryno mike | Team Losi Comp Crawler | 6 | 03-18-2012 07:42 PM |
i need new motor running 9v | fordlightning + jeep | Electronics | 6 | 03-15-2012 06:05 PM |
what motor are you running? | rc2008 | Losi Mini-Rock Crawler | 1 | 01-07-2012 10:54 AM |
What motor are you running.... | 88_Pathy | Venom Creeper | 23 | 04-28-2009 05:33 PM |
motor always running | gpage13 | Electronics | 2 | 08-22-2008 04:33 PM |
