11-24-2020, 05:35 PM | #1 |
Quarry Creeper Join Date: May 2020 Location: Canada
| Cab only mounting?
How do you guys mount those cab only bodies? Obviously you can use the front body posts but what's the most common way to mount the "back"?
11-24-2020, 06:23 PM | #2 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
| Re: Cab only mounting? |
11-24-2020, 07:42 PM | #3 |
Oh really? So it just sits on the frame rails?
11-24-2020, 07:50 PM | #4 |
11-24-2020, 07:51 PM | #5 |
Rock Crawler Join Date: Apr 2008 Location: pittsburgh
I made my ascender blazer body into a square body pickup, then, in another phase, chopped the bed off to make it cab only. I had made a styrene interior that was relatively heavy. The 2 front posts were not enough. I made a "hook" in back out of a u shaped piece of metal that locked into one of the frame rails. The bottom of the interior keyed to the frame also. For a heavy cab I needed a 3rd spot for the cab to grab onto to keep it all in place. If your just using a Lexan cab, the 2 posts will work. Sent from my moto e5 cruise using Tapatalk |
11-24-2020, 08:30 PM | #6 |
Im kind of debating cutting the sport body bed off. But i guess id have to close the back of the cab off somehow aswell if i did that.
11-24-2020, 09:12 PM | #7 | |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
| Re: Cab only mounting? Quote:
I’m doing pretty much the same thing, except with the Bronco body. Just get a 12”x12” sheet of lexan off Amazon, and measure twice cut once! Sent from my iPad using Tapatalk | |
11-24-2020, 10:50 PM | #8 |
How are you sticking that together? Just tire/wheel glue or something?
11-24-2020, 10:52 PM | #9 |
11-25-2020, 06:15 AM | #10 |
Rock Stacker Join Date: Jun 2018 Location: Florida
You can mount 2 body posts horizontally, either off the bed or cage if you have one, or off of the sliders. Use them just as guide pins to hold the body and use the front posts with clips to secure it. Just helps from flopping around. I’m running a Salinas bed with my power wagon cab with 2 post facing forward, and magnets for the front mount.
11-25-2020, 12:33 PM | #11 | |
Pictures? I’m interested on how you did this, but not quite understanding. Sent from my iPad using Tapatalk | |
11-26-2020, 02:17 PM | #12 | |
https://youtu.be/F1yiy2G2oak @5:30. Mine is more similar to this https://youtu.be/A6rCtJ3ctfo @6:30 I am not affiliated with this video, but this is a sweet build. Last edited by NABeast; 11-26-2020 at 02:22 PM. | |
11-26-2020, 02:32 PM | #13 | |
Thanks! I have a few extra posts on hand, I may try this. Sent from my iPad using Tapatalk | |
Cab only mounting? - Similar Threads | ||||
F350 cab mounting | wcdfmt510 | 1.9 Scale Rigs | 6 | 04-11-2018 03:03 PM |
scx10 (mojave cab only Mounting)????? | mrkdubaya | Axial SCX-10 | 7 | 05-27-2013 04:24 PM |
mounting the toyota hilux cab in scx10 | crawler nub | Axial SCX-10 | 0 | 06-26-2011 12:50 AM |
hilux cab mounting ideas? | t-oda | Axial SCX-10 | 6 | 09-09-2010 07:37 PM |
Help! hilux cab mounting help! | rccrawler66 | 1.9 Scale Rigs | 3 | 02-21-2010 07:55 PM |
