![]() | #1 |
Pebble Pounder Join Date: Aug 2014 Location: Merrimack
So I’m thinking about adding a winch and have no idea which one to get. Also I probably need a new bumper. What ideas do any of you have? ![]() |
![]() | #2 |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
I’ve never owned one, but a lot of people have good luck with the RC4WD Warn winch, and at $35, might as well try it out. Is there any flat spot on that bumper? It comes with a mounting plate. https://store.rc4wd.com/RC4WD-110-Wa...ch_p_3734.html RC4WD also has a winch controller for it, I don’t think it’s included with the winch though. Sent from my iPad using Tapatalk |
![]() | #3 | |
| ![]() Quote:
I was looking at those. If I go that route I’d need a new bumper. Which I’m still trying to find one that looks good for my truck. The bumper I have does have a spot for the cable to come through, I’ll just have to cut the diamond plate. I’m kinda leaning towards a servo winch. Just need to figure out which one and a mounting plate. | |
![]() | #4 |
RCC Addict ![]() Join Date: Jan 2016 Location: Kelowna, BC
Whatever you do, DON'T BUY TAHT RC4WD WINCH CONTROLLER!!! It's bulky, not waterproof at all and they fail regularly. It's junk. There's a vendor on here (HeyOK Performance) and he makes a $25 winch controller that's leaps and bounds better than the RC4WD junk; tiny, waterproof and reliable. He also makes another style that's a little bit more money but can run higher voltages so your winch will be faster and stronger. He also has a wireless option available as well if you don't have an extra on your Tx to run a winch. As far as the winch itself, a good bet is the RC4WD Warn winch but the best bet (for a scale inch anyways) is the RC4WD scale 8274. The free spool option is mucho excellente to have when you need to spool out line for far away pull and it's crazy strong... |
![]() | #5 | |
Quarry Creeper Join Date: Jul 2020 Location: US
| ![]() Quote:
x154! I have so far, only tried a few of HeyOK's Aux channel switches. (Allows me to turn on/off my lightbar(s), rock lights, etc via my Transmitter. But the products are "on fleek". Nice presentation, perfectly executed function, as well as HELLA-affordable! @heyok could you please point this lad in your web-store's direction? R.C. means both;Remote control, and Rock Crawler. | |
![]() | #6 |
Pebble Pounder Join Date: Jun 2020 Location: Baton Rouge
Friends trx4 its the 8274 winch and hot racing front bumper. I think there was some drilling/ cutting to get the winch on. This one has plenty of power as well. ![]() ![]() Sent from my SM-N975U using Tapatalk |
![]() | #7 |
Bowhouse servo winch mount with a servo winch. Works out well! ![]() |
![]() | #8 |
Rock Crawler ![]() Join Date: Jun 2015 Location: In the Sticks in the Ozarks
Yep, gotta agree with Queso'. ![]() ![]() ![]() Then you just need a hole in the bumper and a fairlead, not a new bumper. ![]() Just my 2 cents. ![]() ![]() Last edited by dr frankenstyle; 12-03-2020 at 03:55 PM. Reason: oopsy poopsy |
![]() | #9 |
Go Buckeyes! ![]() Join Date: Jun 2017 Location: Mid-Ohio
Another option for a winch is a servo winch with a 3D printed mount or homemade mount to fit in between the inner fenders. I've burn't up too many of the RC4WD winches, so I went with the 3Brothers Overlander winch. This winch mount is a 3D print from 3DtoRC on Thingiverse. It is an easy print and fits great! ![]() ![]() |
![]() | #10 |
Thank you all for the mention of my winch and light controller products. This link will take you to winch items in my web store: https://www.freewebstore.org/heyok-p...3_1588136.aspx Thanks, Al |
![]() | #11 | |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
| ![]() Quote:
If you want a scale winch that really really works get the RC4WD Warn 8274. I have mounted a winch on a cheap 15 dollar stinger I got on Amazon and it works great BUT it moght not look right on your RC. | |
![]() | #12 | |
| ![]() Quote:
Another option is to go full-retard with it. I have also designed a winch using a 1/18 scale transmission that is an absolute beast. I am using this in my TRX6 (post #24), the base for this is also on my Thingiverse channel. Greatscott's TRX-6 | |
![]() | #13 |
RCC Addict Join Date: Aug 2020 Location: Jacksonville
Gonna throw a dumb question in here - - - is the second servo slot on the front of an Enduro frame for a servo winch, or is it just in case you want to switch the steering/panhard/all of that to the passenger side for some reason?
![]() | #14 |
![]() | #15 |
*cool...Googles price of winch and controller...decides to pick up truck with his hands lol. I may do this eventually, it is intriguing but gotta buy like 8lbs of brass things first haha.
![]() | #16 | |
| ![]() Quote:
Anyone know why? Seems like u can put ur servo in a bit of danger on the rocks? If u have personally done it, whats the Pros? R.C. means both;Remote control, and Rock Crawler. | |
![]() | #17 |
| ![]() A 20kg continuous rotation servo can plug right into a spare receiver channel with no external controller needed, is strong enough to deadlift a 10+ lb truck and can be had with an aluminum winch spool for about $30.
![]() | #18 | |
| ![]() Quote:
Ahhh. I was under the impression it needed to be regulated due the creep and what not. Certainly is affordable if you go that route. | |
![]() | #19 | |
| ![]() Quote:
I do have a few of the cheap 20kg and 25kg servos from Amazon that I did turn into servo winches. Paired up with a HW 1060 or 1080 ESC and they make for a very strong winch. I have yet to destroy one of those! The mount you designed and shared on Thingiverse is very nice! Thanks for sharing it! ![]() I had the creep problem with my first servo winch I made out of a 20kg Amazon servo. Even after super gluing the potentiometer, the servo still liked to ever so slightly creep out. That was a pain in the butt to deal with, so I solved that problem by hooking up a HW1060 ESC. Works great and no creep! | |
![]() | #20 |
Quarry Creeper ![]() Join Date: Mar 2007 Location: Celina TN.
Can anyone tell me if i can power the wireless winch controller off the spare jst connector coming off of the XL5 esc? And yes it is the RC4WD controller. I figuered I've already got it so might as well try to use it. When it craps out I'll go with the controller mentioned in the earlier comments. Thanks in advance and sorry for hijacking the post.
impulse winch buy, rc4wd, custom bumper and winch pull test | evan03 | Axial Wraith | 13 | 03-10-2013 09:15 PM |
