Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: TRX-4 Defender build notes
Old 12-27-2020, 02:14 AM   #1
Default TRX-4 Defender build notes
Had an eye on this kit for a very long time. Finally a letter to Santa and it came true
For the Defender body, the 8057 short to long chassis conversion kit is needed (that I knew of) AND 8215 body posts (missed that one...)
Never build a Traxxas kit, some things are different, but I like them:
  • I really like that each major stage has it's own bag and there are (almost) no extra parts making you wonder if you missed something
  • Don't really complain of links and shocks coming preassembled
  • Also no complains of parts coming already detached from part trees
  • Radio pre-programmed; since it does not have a display and the bluetooth module is not included, this is a real plus
All in all, surpisingly pleasant build experience.
A few build notes:
  • That's a lot of screws
  • When tightening slipper, watch for spur wobble - easier to fix it at this stage
  • Front portal input gears tend to rotate inside their bearings - a little grease fixes that
  • Servos are labelled - I did not notice
  • Wire routing for diff lock servos is a bit tricky since they have a "bulge" on the cable and there is little space between them and chassis. Beware of pinching the cables
  • Due to extension kit, you'll need the two 3x12 screws that are normally used on battery tray on rear shock towers - no issue, you'll be left with two 3x10 to use on fixing the tray
  • Extension kit instructions are a bit small, pay attention to rear shock towers orientation
  • Really, that's a lot of screws, my right hand is filing a complaint as we speak
After chassis assembly I was left with two 3x10 screws, but can't figure out if they are extras or I missed something. Besides parts not used because of the conversion kit, these are literally the only extra parts left.
Question: according to manual, plastic to plastic and plastic to metal rotating parts are not greased (gearbox fork; pinion to spur). Is it wrong to grease them?
danb1974 is offline   Reply With Quote
Old 12-27-2020, 06:34 AM   #2
Default Re: TRX-4 Defender build notes
A few build notes:
Only thing I would add on is, if your planning for heavy water or dusty dirty use do your self a favor now and get 3 in 1 dry lock or something similar. Coat all your screw heads with it, this will help prevent dirt getting in the hex which if not cleaned out can cause it to strip out easy. (I know it sounds dumb but these are really easy to do that, I learned the hard way)
Also, if you want to lube or grease those gears, cables, forks, shock body threads anything that needs to slide, rotate that can get dirty i would also use the dry lock on as well. Gives enough lubricant, and keeps dirt out and will keep stuff from getting rusty if your in water. Do the motor brushes as well but don't over do it, the stock motor will burn up in heavy water abuse (when the truck is swimming at full throttle) this helps keep the brushes clean and just add some between runs.
Sent from my Pixel 3 XL using Tapatalk
mitch.douglas21 is offline   Reply With Quote
Old 12-28-2020, 09:39 AM   #3
For now it's indoor only, want to keep it clean but also minimal gear noise
Two more notes:
  • Do not mix up threadlock coated screws (steering servo and pinion) - nice touch traxxas
  • Beware of pinion position, a tad to the back and the screw will scratch the spur at each rotation
Any ideea where I can order scale accessories with combined shipping, or sold as sets (things like barrel, box, shovel, luggage net etc.)
Old 12-28-2020, 11:03 AM   #4
Two more notes:
You can get those from many places. Ebay, amazon, local hobby shops, shape ways and other 3d printed sites and more. Rc4wd has some as well
Old 02-20-2021, 02:09 AM   #5
Having a faint clicking in the high gear. Before I take apart the gearbox... anybody else had that?
Old 02-20-2021, 07:38 AM   #6
I coat everything that rotates, and even some things that don't....bearing pockets, gear shafts, bearing faces - it all gets a light coating of grease. I use a light Penzoil grease for plastic on plastic and Red and Tacky for metal gears.
The only thing that should not be lubed up is the shift fork for the diff unlock in the axles. Seems to clog up the fork for some reason.
OSRC is offline   Reply With Quote
Old 02-20-2021, 04:57 PM   #7
If you mean a ''click'' sound right after you switch gears, as you press the throttle, it probably comes from the gear servo as it gets into position.
xagoras is offline   Reply With Quote
Old 02-21-2021, 06:22 PM   #8
Even though my trans is single speed, I have a faint ticking that’s rpm dependent.
I’m attributing it to the driveshafts are out of phase from the factory.
Transmission tear down and re-do is on my to do list.
Benp is offline   Reply With Quote
Old 02-22-2021, 07:03 AM   #9
Double check and make sure the grub screw in your pinion isn't hitting the spur.
That grub screw is right up against the side of the pinion teeth.
I had the same noise and had to move my spur gear front on the shaft a little farther.
M_Saint is offline   Reply With Quote
Old 02-22-2021, 09:41 AM   #10
Thanks!
I’ll check that out
Old 02-22-2021, 12:16 PM   #11
Yep, that’s happened to me a few times. Very annoying when out on the trail and all you hear is ticking lol.
_________________
SCX10 ii
TRX4
ScaleLifeNewbie is offline   Reply With Quote
Old 02-23-2021, 10:24 AM   #12
Actually that should have read "I had the same noise and had to move my pinion gear front on the motor shaft a little farther" but yous got the jist
Old 02-23-2021, 11:19 AM   #13
Inspector86's Avatar
OP post pics of your rig, in case you hadn't noticed we love pics.
Inspector86 is offline   Reply With Quote
Old 03-17-2021, 07:57 AM   #14
Had the "pinion screw hitting spur" right after build, fixed at that time. What's left is a constant speed dependant faint clicking only while driving in high gear (not the gear change noise).
Oh, yeah, pics, sure. Most are before the scale accessories arrived, while I was exploring various "how did I got into this position" moves.
Hint: put different size empty boxes under the rug for a bit of indoor fun.
TRX-4 Defender build notes - Similar Threads
goodkid's TRX-4 Defender so far.. goodkid Traxxas TRX-4 2 04-25-2020 09:37 AM
Dabbler's TRX-4 Defender johnnyluv Traxxas TRX-4 15 10-10-2019 08:50 PM
TRX-4 Defender Modification Suggestions CodeEzra_RC Paint and Body 6 05-01-2019 11:14 AM
Tuanies' TRX-4 Defender & Bronco build logs tuanies Traxxas TRX-4 43 04-22-2019 08:42 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
