01-14-2021, 02:32 PM | #1 |
Pebble Pounder Join Date: Aug 2014 Location: Merrimack
| Spur gear
Pros and cons of the HR steel spur gear.
01-14-2021, 02:38 PM | #2 |
RCC Addict Join Date: Aug 2020 Location: Jacksonville
| Re: Spur gear
Louder
01-14-2021, 02:41 PM | #3 |
| Re: Spur gear
More expensive.
01-14-2021, 02:56 PM | #4 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
| Re: Spur gear
Removes a relatively cheap and easy-to-fix point of failure which helps protect the rest of your drivetrain. Can’t really think of any pros. If one is roasting through plastic spur gears in a crawler or trail truck to the point of needing a metal replacement then there are likely problems somewhere else in the drivetrain or with gear mesh. |
01-14-2021, 03:48 PM | #5 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
| Re: Spur gear
I'm actually ditching the steel spur gear in my wroncho for a stock plastic spur and a slipper Eliminator. Like Topher said, I want a cheap point of failure. Right now I really don't have one Sent from my LM-G710VM using Tapatalk |
01-14-2021, 04:02 PM | #6 |
Rock Crawler Join Date: Apr 2020 Location: Northern MN
| Re: Spur gear
It’s pretty noisy but not too bad. I had no issues performance wise with it. I switched back to traxxas spur and it quieted down. |
01-14-2021, 05:50 PM | #7 |
| Re: Spur gear
Looks like I’m sticking with the stock plastic.
Spur gear - Similar Threads | ||||
Is there a metal upgrade gear for the 80T spur gear? | maddogs1965 | Axial Wraith | 9 | 03-25-2014 11:31 AM |
Which pinion gear works best with RC4WD Steel spur gear? | e32lover | HPI Wheely King | 8 | 03-10-2013 06:09 PM |
Which spur gear and pinion gear with 35t motor | vegas1973 | General Crawlers | 1 | 08-19-2012 11:42 AM |
Micro T spur and Micro Crawler spur gear. Same thing? | matts175 | Losi Micro-Rock Crawler | 4 | 10-15-2011 01:18 AM |
Wobbling spur gear....Need alum. gear hub! | sickfab | HPI Wheely King | 26 | 10-01-2007 02:09 AM |
