12-29-2020, 10:03 PM | #1 |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
| Rear driveshaft issue
Hey y’all, So I noticed the other day that when I would throttle, my front axle would spin a lot faster than my rear. I had my trailer on at the time, so I thought it was just the weight of the trailer lifting the front axle up off the ground, therefore letting it spin faster having less resistance on the ground. Well, I took the trailer off and it did the exact same thing. Well, I inspected the rear driveshaft, and surely enough I was missing a screw. I didn’t have any screws that would fit on hand and I had a meet up the next day I really wanted to go to. So, I took(Redneck DIY alert) an eyelit and E6000’d it in there so I could go to the meet up. It lasted that day and a few others, but now it’s wobbly and I need to fix it for real this time lol. So my question is, does anyone know what screw/pin size goes here? I was looking on the assembly kit and I didn’t see anything. Thanks in advance. https://postimg.cc/c6dcj8H6 Sent from my iPad using Tapatalk |
12-29-2020, 10:28 PM | #2 |
Newbie Join Date: Dec 2018 Location: in the workshop
| Re: Rear driveshaft issue
Search for this: Traxxas #8221 Its that 3x10mm screw pin Sent from my ONEPLUS A6010 using Tapatalk |
12-29-2020, 11:01 PM | #3 |
| Re: Rear driveshaft issue |
12-30-2020, 04:56 AM | #4 |
Rock Stacker Join Date: Nov 2020 Location: US
Not sure if they come stock like this or not, I'll have to check mine, but you can overdrive the front and or underdrive the rear axle gearing. The is used for crawling to give the front that extra advantage to pull the truck over rocks vs be pushed over them by the rear. So that's why the front would be spinning faster than the rear. Sent from my Pixel 3 XL using Tapatalk |
12-30-2020, 07:04 AM | #5 |
As you've found out those through pins have a tendency to loosen up over time and torque cycles. Best to torque check them, and the wheel nuts, between runs.
12-30-2020, 09:45 AM | #6 |
Rock Crawler Join Date: Apr 2020 Location: Drums
Are you saying you lost the screw that hold the driveshaft onto the pinion gear or the small pin (non-threaded) that goes through the actual reticulating ball in the driveshaft? The photo looks like the latter.
01-15-2021, 12:59 PM | #7 |
UPDATE: Just to be clear, it is NOT the screws the first comment recommended. I found out right after I ordered those, it is the non-threaded pins that slide in I was missing. OnTheTrail was correct. |
01-15-2021, 01:46 PM | #8 |
Rock Stacker Join Date: Dec 2020 Location: London, Ontario
| Re: Rear driveshaft issue https://traxxas.com/products/parts/8295 Not cheap, might I suggest a drill bit that you cut to length. likely stronger than the traxxas part anyways. |
01-15-2021, 01:57 PM | #9 | |
| Re: Rear driveshaft issue Quote:
Rear driveshaft issue - Similar Threads | ||||
Yeti Kit Rear Driveshaft Issue | stone202 | Axial Yeti | 8 | 11-13-2015 10:18 AM |
MIP driveshaft issue | rob4607 | Axial Yeti | 11 | 09-27-2015 09:32 PM |
driveshaft issue | Exocaged | Axial AX-10 Scorpion | 3 | 11-12-2013 10:52 AM |
Driveshaft rings issue | DrtRacr440 | Axial AX-10 Scorpion | 9 | 08-19-2009 05:20 PM |
Driveshaft issue | Mav-1981 | General Crawlers | 10 | 05-16-2009 08:59 PM |
