Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Our TRX4's, with a few mods planned.
Old 01-12-2021, 03:16 PM   #1
Default Our TRX4's, with a few mods planned.
New to the crawling scene so figured I'd show our two and post future modifications here.
Sport and G500'd bodied snap-on ed.
Made the fake plastic winch look a bit better for a few quid.
Few more changes to the G500, roof lamps, decals, and grill mod.
I'm currently on with doing some quite serious body changes, I'll post pics when I'm done.
I do also have some electrics things to sort when I get round to it, namely 36kg servo, uprated BEC etc.
JonnyUK is offline   Reply With Quote
Old 01-12-2021, 03:44 PM   #2
Default Re: Our TRX4's, with a few mods planned.
Made some wheel weights for crawling stability.
Free mod because I used some lead bar I had.
Wheel weight before and after.
Extra set of wheels/tyres (on the left) for when I'm not playing on the rocky cliffs and don't need the heavier wheels.
Old 01-12-2021, 05:22 PM   #3
Go Buckeyes!
B-MOW71's Avatar
Welcome to RCC and the tiny truck world!
Winch looks great with the steel cable and hooks!
B-MOW71 is offline   Reply With Quote
Old 01-12-2021, 05:28 PM   #4
Thanks buddy!
Old 01-19-2021, 05:11 PM   #5
I've been doing a few things, such as: cutting out solid panels to add clean lexan windows, fitting black plastic wheel arches, fitting diamond plate aluminium treadplate, fitting bulbs in the roof lamps, adding the Savox servo with metal horn and external BEC, trimming front plastic for wheel clearance under full lock compression, making front and rear bumpers out of aluminium sheet and fitting modified rear ladder.
I've still got a few more things to add/alter later this week.
I decided to give the G500 a more rugged look, even more so once we can get outside and get it dirty and bashed about!
Went for the bolted in plexiglass look with tiny (m1.2/1.4/1.6) stainless bolts and rivet heads.
Old 01-19-2021, 05:12 PM   #6
Old 01-19-2021, 05:13 PM   #7
...and a pointless photo of a BEC kit that you can't see!
Once I have my airbrush set up working I might do some aging/weathering effects to the shell etc, I need to practice on a few things before committing though.
Old 01-19-2021, 06:13 PM   #8
That looks really cool!
I like the bolted in plexiglass look!
The diamond plate accents are sweet!
Benp is offline   Reply With Quote
Old 01-20-2021, 11:34 AM   #9
How did you get the wheels to fit over the portal cover with those wheel weight inside? I would have that they would have gotten in the way.
OnTheTrail is offline   Reply With Quote
Old 01-20-2021, 11:50 AM   #10
Do all of the G500s bodies sit that high? Seems to be pretty tall compared to the other versions.
Phildirt is offline   Reply With Quote
Old 01-20-2021, 01:46 PM   #11
The wheels are 2.2's so have a few millimetres of clearance from the lead weight.
No room for portal brass weights of course but I don't intend to fit any on this.
Old 01-20-2021, 01:48 PM   #12
Its one of the lifted Snap-on edition models but altered to fit the G500 shell.
Old 01-20-2021, 02:34 PM   #13
Is Snap-on an available brand in the UK or did you just snap this one up > as it's rare?
Old 01-20-2021, 02:50 PM   #14
The Snap-on tool brand is quite common in the UK too, maybe not as much as in the USA.
Not many of these snap-on trx4's seem to be about in the UK really, I've seen a few though but all with the standard bodies.
Old 01-20-2021, 02:56 PM   #15
Swapped the motor cog to a lower 9T.
Also fitted cooling fans to the motor and ESC. I'll only use them in the middle of summer when its blazing hot, peace of mind that things are been helped to keep cool.
Contacted Fastrax to confirm the voltage range of the two fans on the motor, after no reply (ignorant!) I searched online and managed to find the manufacturers spec sheet in Chinese/Japanese. Translated it and the range seems to be 3.5v-7v so I figured it would be ok at 7.4v when fully charged. Ran them for 30mins and all good.
Tidied up the wiring after soldering on some jst plugs. They turn on/off via the ESC plus I added a master switch with space for another switch if needed in the future.
The ESC kit handily came with a slim lever so I can turn on the rig from below.
Added a spare wheel to the roof. Made it out of polystyrene so it weighs next to nothing.
I used this plastic waste...
...to make a bolted together roof rack extension...
...and bolted it through the roof here!
The rack is almost finished but you get the idea.
Old 01-20-2021, 03:56 PM   #16
Make sure you secure those scale bits really well. When I was brand new to this hobby I thought I’d add a bunch of things to my rig and it all went flying off the first rollover. Re-engineered it and it lasted about 5 more rollovers, then gave up and decided I like rollovers more than scale bits haha.
Old 01-20-2021, 04:50 PM   #17
Good point. But also a good reason to make more
If I had my welder here I'd have made a custom rack.
Next time I do one I think I'll source some small diameter copper rod and solder it. Could make nudge bars and all sorts that way.
Old 01-22-2021, 02:51 PM   #18
So the cheap alloy bead lock rings (£8 delivered) that came from China didn't fit the intended wheels, wrong shape to grip onto the tyres beading.
So instead I decided to change the look of the Traxxas wheels with them, I wasn't a big fan of the red plastic ones anyway.
Took a bit of messing about but I'm quite happy with the end result.
Old 01-26-2021, 03:37 PM   #19
Added a truck bed to the Sport.
Old 01-26-2021, 05:39 PM   #20
That is cool!!!!
Our TRX4's, with a few mods planned. - Similar Threads
TRX4's are Tough! JimInMiami Traxxas TRX-4 6 06-09-2020 08:08 PM
Trx4's going to the recon G6 in Pa? solo1 Chit Chat 2 06-26-2017 06:40 AM
Planned Obsolescence losikid Chit Chat 20 08-03-2014 07:20 PM
WTF was this planned? chicostaxxs007 Chit Chat 6 12-10-2011 05:41 PM
My Planned AX-10 Rig dmward1978 Newbie General 8 04-14-2009 06:59 AM
