01-13-2021, 03:47 AM | #1 |
Newbie Join Date: Jan 2021 Location: Bc, Canada
| New reciever?
I'm really close to buying a trx4 bronco but I want to be able to use the flysky gt5 radio I got with the gen8 since it sounds like it's a better radio anyways. I'm very new to this hobby, is it as simple as buying a bs6 receiver (or any other compatible with my radio), unplug the wires from the traxxas receiver, plug them into the bs6, then bind it and do all the end point adjustments? Sorry if it's a silly question but I've been searching various resources for a while now and can't find relevant information. How's a noob to know if he's going to light his new rc on fire or not. |
01-13-2021, 04:46 AM | #2 |
Pebble Pounder Join Date: Aug 2020
| Re: New reciever?
I’m no expert but to my knowledge, yes it really is that simple. Esc powers receiver and and receiver binds to transmitter. I switched to a cheap flysky because of how much I hated the stock radio on my scx10.2. Literally swapped receivers, bind, and I was crawling again with lots more adjustments. Sent from my iPhone using Tapatalk |
01-13-2021, 06:52 AM | #3 |
| Re: New reciever?
You just need to set up a new model on the radio, then mind the receiver to that model and you are in business.
01-13-2021, 10:17 AM | #4 |
Rock Crawler Join Date: Apr 2020 Location: Northern MN
| Re: New reciever?
I’ll echo what has already been said. Yep. That easy. I’m running both Trx4 and new to me Gspeed on my GT5. I just switch back and forth between the models. No issues. |
01-13-2021, 11:00 AM | #5 |
| Re: New reciever?
Awesome, thanks for the replies everyone!
01-13-2021, 11:25 AM | #6 |
Rock Crawler Join Date: Apr 2020 Location: Drums
| Re: New reciever?
Just make sure you're careful when setting up the center, end points and servo reversing for the two diff lock servos and the 2spd servo. I'd recommend disconnecting the ball joint off the servo savers on all three of those BEFORE you plug them into the new receiver. Make your adjustments by eye and then snap the ball back on. Also keep in mind, you'll most likely end up using the two rotary channels on the top of the TX. One for each of your lockers. While I haven't converted either of my TRX4s yet, from my under standing, the three position switch can only be used for the diff locks if you have a way to reverse the direction of one of the servos. This usually is only done with an inline servo reverser, or a programmable servo.
01-13-2021, 02:04 PM | #7 |
RCC Addict Join Date: Nov 2017 Location: 3rd rock pile on the right
| Re: New reciever?
U can also use the flysky fs-ia6 rx with the gt5. Its a lil bigger than the bs6 n the it plugs in from the end, not the top. Thats wat ive been using, they were a lil cheaper than the bs6
01-13-2021, 10:10 PM | #8 | |
| Re: New reciever? Quote:
01-13-2021, 10:11 PM | #9 |
| Re: New reciever? Damn, I immediately ordered a bs6 and a couple more batteries from Amazon lol.
New reciever? - Similar Threads | ||||
Reciever help | Motorhead | Electronics | 1 | 08-25-2010 09:05 PM |
What reciever? | mmbackpacker | Electronics | 2 | 08-30-2008 02:11 PM |
reciever help | mattman23 | Electronics | 1 | 10-21-2007 03:23 PM |
