01-28-2021, 10:02 PM | #1 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
| What's the consensus on the ver.2 Traxx Pods?
When the TRX-4 Traxx pods first came out, people tested them in mud and snow and found that they slipped way too much, and also clogged easily. Traxxas has since changed the tread pattern from chevrons to paddles; how much difference does this make in the real world? Also, have the problems with clogging and slipping belts improved at all, or at least have people figured out how to reliably solve these problems after purchase?
01-29-2021, 06:46 AM | #2 | |
Rock Crawler Join Date: Apr 2020 Location: Northern MN
| Re: What's the consensus on the ver.2 Traxx Pods? Quote:
I don’t have the tracks but here are my thoughts. In snowmobile applications, minimal lug track compared to a paddle track is a huge difference in deep snow. The minimal lug track will get stuck a lot more and won’t be able to go near the same places a paddle track will. So, for the Trx4 both track sets have the same flotation from the tracks but the paddle will offer much better traction than the chevron. As far as improved reliability of the track system I don’t know | |
01-29-2021, 06:51 AM | #3 | |
I don’t have the tracks but here are my thoughts. In snowmobile applications, minimal lug track compared to a paddle track is a huge difference in deep snow. The minimal lug track will get stuck a lot more and won’t be able to go near the same places a paddle track will. So, for the Trx4 both track sets have the same flotation from the tracks but the paddle will offer much better traction than the chevron. As far as improved reliability of the track system I don’t know ETA - no clue why this double tapped | |
01-29-2021, 10:53 PM | #4 |
Yeah, I've seen videos of the new ones in snow and they do seem to work better, but that could also be the result of people cherry-picking good bits of video where the new tracks happened to work particularly well. I was hoping for more firsthand accounts of using them before I drop 200 bucks to try them out.
01-30-2021, 06:05 AM | #5 |
Pebble Pounder Join Date: Aug 2014 Location: Merrimack
I tried out the new deep tread Traxx. Not worth the money in my opinion. I took off all the brass to reduce weight as much as possible. They worked fine indoors but in 4 inches of snow they just dug in and sank. Only way I could move was second gear and full throttle.
02-10-2021, 10:27 AM | #6 |
RCC Addict Join Date: Feb 2012 Location: UK
Be better off putting some over size tires on it like the Toyotas modified for the Arctic runs. Sent from my ONEPLUS A6013 using Tapatalk |
02-10-2021, 11:37 PM | #7 | |
I was talking to someone, somewhere, who said that the Traxx pods would work a lot better if the treads were fiber-reinforced like drive belts, so they wouldn't stretch and slip when mud or snow gets packed into the drive pulleys. But even so, the pods look a bit narrow to drive on really soft surfaces like snow and wet mud. On soft surfaces, there is no replacement for a large contact patch. Last edited by fyrstormer; 02-10-2021 at 11:43 PM. | |
02-10-2021, 11:41 PM | #8 |
| Re: What's the consensus on the ver.2 Traxx Pods? Hmm. Now you've got me contemplating fitting a set of 2.2" stadium-truck wheels and tires with a set of hub spacers. Though even that might not have a big enough contact patch to keep from sinking in. Snow might be one surface where the non-linear scaling of physics prevents a RC truck from being able to drive on it without being custom-built for the purpose.
02-11-2021, 06:30 AM | #9 |
The Short Course Fling Kings Jr. in the 3.0/2.2" size might be relatively easy to fit (1.75”W x 4.45”H) But I'd think a custom setup using the new JConcepts Fling Kings Jr. in the 2.2" size might be the best for snow... they're 2.5"W x 5.50"H: |
02-11-2021, 08:39 AM | #10 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
Personally, I have had a blast with the Traxx. Started on the chevron patterned and switched to the deep lug when they were released. I found the paddles made a world of difference. Keep in mind I use my Traxx in snow exclusively. For me, they are a means to running my X4 in conditions I could not otherwise run in. For this reason, I consider them a success. I have also set my X4 with a lot of power relative to what is suggested and have NOT geared down. The power is the difference maker in some situations, but one has to be conscientious of not abusing it. That said the X4 is stout and has, so far, handled it brilliantly for the past couple of winters. I suspect a lot of people expect the rig to be a submarine and are disappointed when they can’t run effortlessly through snow up the windshield. The amazing thing is, with a head of steam and the power I am running I can get up on the snow and get float. Traxx are a relatively complex mechanism. Most consumers are used to the simplicity and effortless maintenance of their traditional tires. If you are not willing to put some thought and consideration into what you are working with then forget about it, stick to tires. Neglect your Traxx and they will return you the favour. Anyway, it appears I am one of the few who continues to have a positive experience with them(at least around here). This surprises me considering I have always thought this platform attracts the true hobbyist, an activity that takes patience and an ability to troubleshoot. Personally, I would not buy traxx to run on terra firma. I like my rigs to run smoothly, and on hard ground these definitely do not(That said, they likely could look pretty cool with the right shell). |
04-13-2021, 10:21 PM | #11 |
Thanks for the detailed feedback. Did you have to modify your Traxx pods at all to make them work optimally in snow?
What's the consensus on the ver.2 Traxx Pods? - Similar Threads | ||||
Shock consensus | emmett751 | Axial Wraith | 7 | 06-10-2015 12:12 AM |
general consensus | minicrawlerguy530 | G-Made Sawback | 9 | 09-24-2014 08:28 AM |
Servo Consensus | jrmbtr | Losi Micro-Rock Crawler | 21 | 04-18-2011 12:14 PM |
Tri-pods | Reflection | Videos! | 0 | 11-27-2009 12:02 PM |
General Consensus ? | mkinnett1 | Tires and Wheels | 3 | 09-16-2009 06:14 AM |
