03-06-2021, 06:09 PM | #1 |
Newbie Join Date: Jan 2021 Location: North Wales, UK
| New Abisma/trx4 clone/improved version.
Thought you might find this intersting... I noticed a few photos of the new 'Absima 1:10 EP Crawler CR3.4 KHAMBA' and its design/layout is very similar to the trx4's. Its due out the end of April in the UK. Currently only a RTR version at around 400GBP A quick glance at the chassis and you'll assume its a trx4. Some specs are:- A realistic designed 5mm CNC machined aluminum frame with a heavy duty aluminum 4-link suspension system. Oil-filled shock absorbers with 3mm piston rods provide a silky smooth and realistic response. Portal axles not only offer a greater distance from the differential housing to the ground than conventional axles, they also have another positive feature. With conventional crawlers, the torque applies so much force that the vehicle jumps over the obstacle. The design of the portal axles reduces the gear ratio at the wheels and virtually eliminates the torque surges of the drive. The overall reduction ratio of the axle drive is more than twice that of non-portal designs to insure a smooth run. A waterproof digital servo with a steering force of 9kg and metal gears is installed. A hydraulic steering shock absorber can be retrofitted as an option (1230544). Hardened steel drive shafts and a steering angle of 45.8° offer the best possibilities to handle any terrain. The CR3.4 KHAMBA features a 2-speed transmission to conquer tough terrain and bring you also fast to the next obstacle. Just push a button on the radio and change from transmission ratio 1/37.1 (low speed) to 1/15.1 (high speed) Lock and unlock the front and rear differential independently to get the maximum performance on the track - all controlled remotly from your tranmitter and 2x 0,9kg mini servos. Leave the differential unlocked for a smooth hadling at high speed. On tecnical trails you can lock the front differential, the rear differential or even both to handle extreme terrain. Aluminum motor mount and an adjustable slipper clutch provide a additional protection in extreme conditions. Hardened steel differential gears and drive parts The drive concept - powered by HOBBYWING contains a 60A waterproof brushed speed controller and a 550 motor. Set the jumper to setup your battery type (NiMH / LiPo) and drive mode ( forward / reverse / brake) 9kg digital steering servo and 3x 17g mini servos for gear transmission and differential lock/unlock - all servos are waterproof The 2.4 GHz 6-channel radio system gives you total control over your vehicle - wether lighting system, 2-speed gear, diff. locks or top speed adjustment Headlights Rear lights Turn lights (while steering) Hazard warning lights (front & rear) Brake lights All these functions are combined in the 6-channel receiver. You want to use another 6-channel radio without loosing the lighting function? No problem! A description how to do you will find in the manual. Stylish 2.2" wheels with beadlock rings and 12 bolt design Super soft tires with a realistic sidewall flex for maximum traction on the rocks Wheel size: 40x115 mm Rock sliders and molded inner fender help to protect the chassis from dirt and damage Body with screw and magnet mount and "easy to open" battery case 1.2mm PC bodyshell with many attachments like Rear view mirrors Roof rack Door handles Full size spare wheel with bracket at the rear Vehicle Specs: Length: 530mm Width: 246mm Height: 255mm Ground Clearance: 53mm Wheelbase: 313mm Weight: 2890g Approach Angle: 60° Departure Angle: 45° Steering Angle: 45.8° Wheels: 12mm Hex Beadlock 2.2" Tires: 40x115mm Shock Length: 90mm Shock Oil Viscosity: 500cps Transmission: 2-speed (Hi 1/15.1 / Lo 1/37.1), Remote shifting Gear Pitch: Module 0.8/32dp - Pinion 16T / Spur Gear 44T Drive System: 4WD Shaft Drive Electronics Specs: ESC: 60A Brushed/Waterproof with T-plug connector (BEC 6V@3A, NiMh/LiPo suitable) Motor: 550 high-torque brushed motor 21T Steering Servo: 9kg MG, digital and waterproof Mini Servos: 0,9kg, waterproof Radio System: 6-channel 2.4GHz radio system (4.8 - 12.0V LiPo suitable) Includes: Absima CR3.4 KHAMBA RTR Model 6-channel 2.4GHz Radio System Sticker Sheet Manual (DE/ENG/FR) Recommended Accessories: The CR3.4 KHAMBA accepts a wide variety of LiPo batteries and NiMH batteries A charger is required which is dependent on the type of car battery 4x AA mignon cells are required for the radio. |
03-06-2021, 06:16 PM | #2 |
Quarry Creeper Join Date: Nov 2020 Location: Greece
| Re: New Abisma/trx4 clone/improved version.
It looks like the Sherpa with a Toyota body on it.
03-06-2021, 06:59 PM | #3 |
| Re: New Abisma/trx4 clone/improved version. |
03-06-2021, 09:21 PM | #4 |
Rock Crawler Join Date: Apr 2020 Location: Drums
This is the same thing as the Yikong that's been out of a couple months: https://www.youtube.com/watch?v=DX9RMgO36S4 https://www.banggood.com/Yi-Kong-Rac...=CN&ID=6287832 |
03-07-2021, 06:47 AM | #5 |
Rock Crawler Join Date: Mar 2019 Location: Terrassa
[QUOTE=OnTheTrail;6071895]... that's been out of a couple months: More like a year and a half |
New Abisma/trx4 clone/improved version. - Similar Threads | ||||
New TRX4 version - Chevy Blazer | svt923 | Traxxas TRX-4 | 91 | 03-29-2019 06:10 AM |
new and improved...... | sidewaystreak | Venom Creeper | 16 | 05-02-2010 02:48 PM |
new and improved wk | crawler4 | HPI Wheely King | 3 | 08-19-2009 01:36 PM |
