03-27-2021, 05:35 PM | #1 |
Rock Crawler Join Date: Aug 2020 Location: In The HIVE
| RCBee has a TRX4 Transmission 2 Speed Question Please Help
Buzzzzz.... Crawlers..... I have a quick question About the transmission gears from a 2 speed Bronco SWB!!! Ok so I have an empty transmission case and want to make Sure I am buying the right gears and shafts and shifter for the 2 speed Transmission let me know if this is what I need or if there are aftermarket options???? BUZZZZ..... Here are the 3 parts: Traxxas 8293X Gear Set, Transmission, Metal (Includes 18T, 30T Input Gears, 36T Output Gear, 2x10.3 pins (5) Traxxas 8292 Transmission Input Output Shaft Traxxas 8289 2-Speed Drive Hub Vehicle Let me know if im missing something??? THANKS AND BUZZZZZ..... |
03-27-2021, 08:04 PM | #2 |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
| Re: RCBee has a TRX4 Transmission 2 Speed Question Please Help
Here’s everything you’ll need. Bearings/: 5x11x4mm (10) 5x8x.5mm (3) 5x10x4mm(1) Spacers: 5x8x0.5mm (4) Pins: 2x9.8(5) Gears: 18T Input gear 30T input gear 24T output gear Drive hub 36T output gear 27T T-Case gear(3) Shafts: Shift dog Input shaft Output shaft Shift fork Long T-case output shaft Slipper: Slipper gear Slipper plate Slipper friction material spring washer (4) 5x8 Metal washer (1) Locknut 2 speed: Shift linkage Oh and by the way I got all this from the online assembly manual. _________________ 79 F150 SCX10 ii TRXWalker |
03-27-2021, 08:49 PM | #3 | |
Quarry Creeper Join Date: Jul 2020 Location: US
| Re: RCBee has a TRX4 Transmission 2 Speed Question Please Help Quote:
Read-Up! Mod-On! Crawl EXCESSIVELY! | |
03-27-2021, 11:57 PM | #4 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
There's a kit including the servo for 50ish bucks. I stuck one in my Sport. Simplest way.
03-28-2021, 12:02 AM | #5 |
Newbie Join Date: May 2019 Location: Skåneland
Traxxas 8196 is the conversion kit, I am considering it myself for my sport. Havent found anywhere how much it weighs though so Im still on the fence a bit Skickat från min SM-G970F via Tapatalk |
03-28-2021, 06:52 AM | #6 | |
Aloha Scale and yes im being lazy using the internet to get my answers I could get but too tired as of late so here I am with all the answers MAhalos.... | |
03-28-2021, 08:27 AM | #7 |
| Re: RCBee has a TRX4 Transmission 2 Speed Question Please Help |
03-28-2021, 08:28 AM | #8 |
RCBee has a TRX4 Transmission 2 Speed Question Please Help - Similar Threads | ||||
RCBee has a TRX4 Servo Horn for Reefs Servos Question Please HELP! | Honeyman108 | Traxxas TRX-4 | 8 | 03-30-2021 07:32 PM |
Question about TH's two-speed transmission | drabina | Vaterra Twin Hammers | 12 | 01-08-2016 06:33 AM |
Custom 2 speed Transmission question | CadToChrome | General Crawlers | 3 | 07-21-2010 04:17 PM |
