Excelsior! Defender Project Santa brought a nice little package, so about time to get it open and see what's in it :ror::ror: https://live.staticflickr.com/65535/...ed4469d6_c.jpg Killerbody Marauder II for TRX-4. Unlicensed open-top Defender, with a roll cage and some scale plastics. Comes with 324mm wheelbase. This body will go on my Camel Trophy chassis, which is 334mm wheelbase, so I will need to make the rear arches a bit larger than the outlined design. https://live.staticflickr.com/65535/...da1f606c_c.jpg Windscreen and dashboard come on a seperate piece of lexan. Cut everything and the body comes out and around 230gr in weight. Not a bad start since I'm aiming at a low weight build as much as possible. https://live.staticflickr.com/65535/...1e7fb876_c.jpg The roll cage is made of plastic. The quality seems OK although it's only 80gr . It should be able to take a couple of hits and rolls :ror: https://live.staticflickr.com/65535/...5fbafcc8_c.jpg Did a test fit to see how everything comes together. I like this open top look. Might even cut the rear part of the roll cage to make it more truck-like https://live.staticflickr.com/65535/...51072e3b_c.jpg At first I was thinking to use magnets to mount the body on the chassis, but after using Bronco's clipless system on my Camel Trophy Defender, I knew I had a winner. It's going to be a challenge to make it work, but I have some ideas about it. https://live.staticflickr.com/65535/...0289d8be_c.jpg |
Re: Excelsior! Defender Project I think shortening the wheelbase on your chassis would be a better idea. Have fun building! |
Re: Excelsior! Defender Project Quote:
That's not an option. I'll put it on the chassis bult for this rig --> http://www.rccrawler.com/forum/traxx...0-project.html so going back and forth everytime will be a nightmare. Extending the wheelbase is easy on this. Just mark and cut the wheel arches more on the rear. |
Re: Excelsior! Defender Project Yeah, but then you'll have a centimeter of nothing in front of the rear wheels :) |
Maybe I'm missing something here, but I don't understand what you mean https://live.staticflickr.com/65535/...8babd7c5_c.jpg |
Re: Excelsior! Defender Project This body can be fitted in 2 different wheelbases, 312mm and 324mm and it has marked cutlines around the rear arches for both. I used the one made for the 312mm on the front of the arch and made another cut around 10mm to the rear to make the wheelbase 334mm. ^^ It came out like the above picture. Killerbody has included a bunch of plastic goodies with this. Not Traxxas quality plastic, but decent ones. Comes with it's own inner fenders, although I won't be using them, since I will install the clipless system https://live.staticflickr.com/65535/...0008f4bb_c.jpg Hard plastic fender flares. I thought about using those, but the plastic is too hard and don't have any flex in it. I fear it could damage the body against the rocks. So I'll probably use the Traxxas ones that have in my parts box which are made of rubber. https://live.staticflickr.com/65535/...fc3bcd5d_c.jpg https://live.staticflickr.com/65535/...06dfdf97_c.jpg Some more plastic scale parts. Again the mirrors will be an issue against the rocks, so might go the same route as the flares. https://live.staticflickr.com/65535/...92dc673b_c.jpg At first the plan was to use the whole Bronco body cage, but It's not really needed and will add extra weight. So I'll just keep the parts needed. It has screw holes exactly below the area needed so I'll use them to mount the inner part that the flares will hold. This will provide an extra point for the clips to hold on the body and add strength. https://live.staticflickr.com/65535/...f4ba65dc_c.jpg https://live.staticflickr.com/65535/...b9630cf8_c.jpg https://live.staticflickr.com/65535/...62ab715e_c.jpg https://live.staticflickr.com/65535/...45be4316_c.jpg The good thing with these clips, is that since I'm mounting them on the body as well, I will be able to adjust the height of the body with some spacers. |
Re: Excelsior! Defender Project Hadn't realised it's almost a month since I updated this thread. Haven't done any real progress on it. I've been waiting for some parts to get here and have been delays. Hopefully I will have the package tomorrow, so I've started doing some side work on it. I haven't started painting the body yet, because I need a clear view inside to mark the holes for the flares. I did paint the seperate pieces however. Colors of choise for this rig will be Tamiya PS-21 (Park Green), PS-5 (Black) and PS-55 (Flat Clear). The PS-55 will be sprayed on the outside to take the shiny effect off and protect the decals. https://live.staticflickr.com/65535/...51ff0d9f_c.jpg I painted the front windshield and then used the inner window masking on the outside as well. I followed the lines of the wipers to cut it. When sprayed with the clear paint, it will leave a clear area to simulate how it looks in 1:1 vehicles. https://live.staticflickr.com/65535/...e81894f6_c.jpg https://live.staticflickr.com/65535/...db9b3e60_c.jpg I'll be using this bumper on this rig. https://live.staticflickr.com/65535/...f40fc2e8_c.jpg I don't have plan on using a real winch with it, but thought that it will look much better with one and already had the parts to make a faux one. https://live.staticflickr.com/65535/...5ffe2e07_c.jpg Printed some Warn stickers, clear coated the whole thing and added another fairlead. https://live.staticflickr.com/65535/...27f5437d_c.jpg Came out pretty nice. Nothing fancy, but makes the bumper look so much better https://live.staticflickr.com/65535/...5cdc7416_c.jpg https://live.staticflickr.com/65535/...1d2b6705_c.jpg https://live.staticflickr.com/65535/...001fba9c_c.jpg |
Re: Excelsior! Defender Project Now that the inner fenders finally got here, it's time to get this project going. I picked up the pace the last couple of days, because we'll have some really good weather tomorrow for painting the body, so had to finish all the prep work on it and get it ready. So, 8018 inner fenders. I needed those to mount the Traxxas fenders. I didn't expect them to be so soft. Thought they were going to be like the normal fenders. They were easy to cut even with a kithen knife. Front ones: https://live.staticflickr.com/65535/...7ee2cdd8_c.jpg https://live.staticflickr.com/65535/...19828eb5_c.jpg Rear ones: https://live.staticflickr.com/65535/...1bed4bc3_c.jpg https://live.staticflickr.com/65535/...b2e1e026_c.jpg Hole marks made on the body https://live.staticflickr.com/65535/...1da311b0_c.jpg https://live.staticflickr.com/65535/...ea87c439_c.jpg And some fine trimming on the fender to clear the already installed fenders. The flat piece left on them, is for mounting them on the clipless system as well, for extra strength. https://live.staticflickr.com/65535/...f18e326d_c.jpg I got Traxxas grille and headlights set for the Defender, to install the Defender lighting system, but they are smaller then the ones that came with this body. https://live.staticflickr.com/65535/...4c1e3174_c.jpg I went ahead and drilled the holes for the lights anyway. https://live.staticflickr.com/65535/...b68e289c_c.jpg I might be able to get away with the headlights parts, but the grille does look odd. https://live.staticflickr.com/65535/...f5b63d73_c.jpg I might end up using the original grille instead https://live.staticflickr.com/65535/...ccdb7599_c.jpg Next was Traxxas mirrors and snorkel set. Again dimensions are a bit off, so some modding was needed. https://live.staticflickr.com/65535/...f7ecea4c_c.jpg The snorkel and the right mirror are supposed to mount on the same piece on the inside, but that is not possible with this body. So had to seperate them. https://live.staticflickr.com/65535/...67b85fea_c.jpg https://live.staticflickr.com/65535/...4a760d19_c.jpg The mirrors were tricky to get there. Because of the way the are mounted, the interior wouldn't allow access to put the screw. I came up with this in the end and drilled a hole on the inside to put the screw. Will probably cover it with something after I paint the body. https://live.staticflickr.com/65535/...b410bc52_c.jpg https://live.staticflickr.com/65535/...22b806e9_c.jpg The tail lights of this body are different than the Traxxas Defender ones. I made a pattern on paper and marked the holes. Took a while, but finally got there. https://live.staticflickr.com/65535/...0a064a5c_c.jpg So, after a lot of measuring, thinking things over and over again, testing mounting, and a rimming marathon the body is almost ready for painting. https://live.staticflickr.com/65535/...f8c2a810_c.jpg https://live.staticflickr.com/65535/...b8d60311_c.jpg https://live.staticflickr.com/65535/...f42f40f6_c.jpg Made me appreciate how easy it is, when the body comes pre-cut and all the holes are drilled from the factory. Tomorrow I'll give it a good wash, get the masking down and hopefully finish painting. |
Re: Excelsior! Defender Project We've got color! https://live.staticflickr.com/65535/...89a31914_c.jpg https://live.staticflickr.com/65535/...ca7008e9_c.jpg https://live.staticflickr.com/65535/...030cb407_c.jpg https://live.staticflickr.com/65535/...20cf20d2_c.jpg Everytime I have to do a 2 tone design, I really appreciate how good Tamiya masking tape in doing the job right. Check the outline of the truck bed. https://live.staticflickr.com/65535/...bff890a8_c.jpg Then it was time to highlight some of the deep lines on the car (doors, bonnet etc). Adds a nice touch and a realistic look of depth to them. Some people use sharpies, but I think they come out very exaggerated, so I prefer to use a thick pencil. https://live.staticflickr.com/65535/...77edf991_c.jpg https://live.staticflickr.com/65535/...c3f5676c_c.jpg I came up with an ingenious solution (🤣🤣) for the smaller headlights problem. I used some vinyl sticker and a marker to cover the area. https://live.staticflickr.com/65535/...a7d9df29_c.jpg https://live.staticflickr.com/65535/...83782884_c.jpg The decals were applied around the car and the interior. https://live.staticflickr.com/65535/...a225422b_c.jpg https://live.staticflickr.com/65535/...365973a8_c.jpg Weather permitting, tomorrow I'll clear coat everything and install the mounting system. |
Re: Excelsior! Defender Project I clear coated the body and started assembling the plastic parts. The kit came with bonnet hinges, but didn't really liked how they looked, so installed these ones I had lying around. They are actually working hinges, so it gave me ideas to cut the bonnet and make it open, but maybe on a later time. https://live.staticflickr.com/65535/...5dcbb884_c.jpg The interior looks better clear coated too. https://live.staticflickr.com/65535/...e289e0b0_c.jpg Went with the kit's grille after all. It makes the car look much better. https://live.staticflickr.com/65535/...97d15311_c.jpg This engine cover from GRC is supposed to fit the Mercedes G500, but I think it works really well on this body. https://live.staticflickr.com/65535/...ce4c1441_c.jpg Some more plastic bits that came with the kit https://live.staticflickr.com/65535/...eb21a752_c.jpg https://live.staticflickr.com/65535/...5c772ef2_c.jpg And the Traxxas Defender mirrors. These gave me a hard time to install them. I finally dropped the plastic inner piece and went with flathead screws that go in from the interior. Hopefully they will hold against the rocks. https://live.staticflickr.com/65535/...efe460c9_c.jpg https://live.staticflickr.com/65535/...b542572c_c.jpg After installing the bits and pieces, it was time for the clipless system. First the fenders and flares https://live.staticflickr.com/65535/...34b4c77b_c.jpg https://live.staticflickr.com/65535/...6c3f0601_c.jpg The front one comes out exactly in the engine vents areas. Some spacers were used to give extra support against the body and it was also mounted on the inner fender flares. https://live.staticflickr.com/65535/...98430563_c.jpg https://live.staticflickr.com/65535/...45c18453_c.jpg https://live.staticflickr.com/65535/...b6af3fe3_c.jpg Same on the rear. The screws and nuts on the truck bed will be painted black. https://live.staticflickr.com/65535/...e7fe3d18_c.jpg https://live.staticflickr.com/65535/...8f21d6ae_c.jpg https://live.staticflickr.com/65535/...ed6b542d_c.jpg I'm not a great fan of the visible screws style fenders, but in this case they do fit the project https://live.staticflickr.com/65535/...c35bc768_c.jpg https://live.staticflickr.com/65535/...43dbf5dd_c.jpg |
Re: Excelsior! Defender Project Managed to get some time to do some more work on this today. Found these engine vents from Team DC, that are perfect for the job. They are elevated enough to hide the nuts that hold the clipless system. Even came with a tool for the tiny screws. https://live.staticflickr.com/65535/...812700cf_c.jpg They blended nicely with the rest of the bonnet https://live.staticflickr.com/65535/...1f531927_c.jpg https://live.staticflickr.com/65535/...c54f5215_c.jpg This light bar will go on the roof. I tried powering it through a 9V battery and it's super strong. I plan to make a switch for it to be able to turn it on, without having to take the body off. https://live.staticflickr.com/65535/...1c950f43_c.jpg https://live.staticflickr.com/65535/...ee71f687_c.jpg The Traxxas Defender snorkel, had to be trimmed a bit to fit. https://live.staticflickr.com/65535/...7372086c_c.jpg Once that was done, the roll cage was ready to be installed on the body. https://live.staticflickr.com/65535/...2bd73396_c.jpg https://live.staticflickr.com/65535/...f069a6eb_c.jpg |
Re: Excelsior! Defender Project Got the switch installed, and without soldering a single wire 🤣🤣 It came with JST plugs, so I just trimmed the side on the male one, and used a servo 1to3 Y splitter plug. Wrapped it in electrical tape, job done! https://live.staticflickr.com/65535/...1aef9bb9_c.jpg https://live.staticflickr.com/65535/...b3dc8a75_c.jpg The switch comes out on the gear decal, so it actually looks like a shifter stick https://live.staticflickr.com/65535/...90a2d3bd_c.jpg https://live.staticflickr.com/65535/...dd8017b4_c.jpg I painted the Traxxas lights with some Tamiya clear paints. They come with color LEDS but the clear plastic makes them look un-realistic when not lit. https://live.staticflickr.com/65535/...91044e8d_c.jpg https://live.staticflickr.com/65535/...cdfc0494_c.jpg https://live.staticflickr.com/65535/...70295814_c.jpg https://live.staticflickr.com/65535/...145db44c_c.jpg The front came out OK, at the end. For the rear, I decided to use some vinyl tape to make the lights outline. I'm not totally sure I like it, but I'll leave it for now. |
Re: Excelsior! Defender Project I had my eyes on the ProLine Trencher G8 tires for some time now, and this project was the perfect opportunity to try them out. So they are finally here and ready to install. https://live.staticflickr.com/65535/...60a0ee6b_c.jpg I'll be using my 1.9 Injora 5 spoke wheels with them, along with some lightly used ProLine dual stage foams. https://live.staticflickr.com/65535/...a2021a49_c.jpg https://live.staticflickr.com/65535/...9263e3af_c.jpg https://live.staticflickr.com/65535/...9990e6ba_c.jpg https://live.staticflickr.com/65535/...bf21ee1e_c.jpg They fit perfectly on these rims. I'm glad I went with the G8 compound, because even that feels a bit soft for the temperatures we get here. I'm a bit concerned about the clearance at full compression but I might just get away with it. Will have to test them on the trail to know for sure. Looks pretty close, however. https://live.staticflickr.com/65535/...b72a46cd_c.jpg |
Re: Excelsior! Defender Project This build is a tribute build, so about time to get the man of honor into the car. https://live.staticflickr.com/65535/...402ece32_c.jpg Stan Lee. The creator of so many comics heroes and basically the reason Marvel is what it is today. The guy created Spider-Man, Thor, Hulk, X-Men and so many more that kept me company on my youth. Passed away on 2018, but his legacy will be with us for a long time. Excelsior! was his signature phrase and moto for life. It's a Latin workd, meaning ''ever upward!''. Thanks for the memories, Stan! I tried to keep this build as clean as possible, so not many scale items on it. Just a couple of these storage boxes will go on the truck bed, to serve a certain purpose. https://live.staticflickr.com/65535/...7a34ff65_c.jpg Stan will be carrying some of the tools of his trade, along with him. https://live.staticflickr.com/65535/...c4c36364_c.jpg And the first appearance of his favorite character of them all. https://live.staticflickr.com/65535/...bbc47673_c.jpg https://live.staticflickr.com/65535/...04303831_c.jpg Found this elastic luggage net from Injora, that seemed like it belongs right into this. https://live.staticflickr.com/65535/...22dc47ff_c.jpg It fits nicely below the roll cage. https://live.staticflickr.com/65535/...2080006a_c.jpg https://live.staticflickr.com/65535/...1fb3c112_c.jpg Did a little light test to check everything works OK https://live.staticflickr.com/65535/...bdfd877e_c.jpg https://live.staticflickr.com/65535/...bd53f6f3_c.jpg https://live.staticflickr.com/65535/...f5dcdff8_c.jpg https://live.staticflickr.com/65535/...abc04125_c.jpg https://live.staticflickr.com/65535/...7237c98b_c.jpg https://live.staticflickr.com/65535/...3b8cf2b8_c.jpg https://live.staticflickr.com/65535/...3a532609_c.jpg Stan looks happy with the setup so far! https://live.staticflickr.com/65535/...576cd8c3_c.jpg Tomorrow he's going to hit the trail, to see what the car is capable of, and get some proper pictures on the wild. |
Re: Excelsior! Defender Project Finally got it out on the trail. Got some pictures, tested the Trenchers and got the first scratches 😂 I like how the Trenchers perform, and they seem to hold well the weight of the car with the Dual stage foams from Proline. But I have the feeling that they might be too soft, when the weather gets a bit hotter. We'll see. I definetely need to make adjustments to the suspension because it's too bumpy. I think I'll try some 20wt oil and maybe softer springs. https://live.staticflickr.com/65535/...5e3ccb08_c.jpg https://live.staticflickr.com/65535/...13abbe86_c.jpg https://live.staticflickr.com/65535/...1c367164_c.jpg https://live.staticflickr.com/65535/...0b5b1c91_c.jpg https://live.staticflickr.com/65535/...1a6c0da3_c.jpg https://live.staticflickr.com/65535/...11632dfa_c.jpg https://live.staticflickr.com/65535/...192be3e5_c.jpg <iframe width="560" height="315" src="https://www.youtube.com/embed/36oJ0r52PTM" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> |
Re: Excelsior! Defender Project Been a while since I had a run with this one. Mostly because a friends kid almost destroyed when I made the mistake to give it to him, without putting it to training mode. The result was broken lexan in 3 corners. So had to wait for some E6000 glue to get here to make the repair, along with some Fibatape. Anyway, it's fixed now and almost no visible damage. I guess this is what happens when you pass the remote to a kid that has zero respect for crawlers 😂. Oh well, lesson learnt the hard way. I didn't get any pictures of the repair process. I was eager to finish with it and get it right. Today we took this one and the Slash down a nearby beach area and had some good time there. Not many areas to crawl but some nice trail spots. It was that perfect time of day leaving/night coming when we headed for the car, so had the chance to actually drive it with the lights on. I realized I didn't have the roof light on, only after I saw the photos on the pc 😂 https://live.staticflickr.com/65535/...798c8a6e_c.jpg https://live.staticflickr.com/65535/...9d00df3a_c.jpg |
Re: Excelsior! Defender Project Stan went fishing today. Had a good catch 😁😁 https://live.staticflickr.com/65535/...9e4fb8c7_c.jpg |
That’s one creepy mofo. Defender looks great out there though Sent from my iPhone using Tapatalk |
Scared the hell out of the kids :ror::ror: |
Re: Excelsior! Defender Project Got some footage while at it <iframe width="560" height="315" src="https://www.youtube.com/embed/kxaT38GgCpM" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> |
