01-23-2022, 06:20 PM | #1 |
Pebble Pounder Join Date: Sep 2020 Location: Canada
| Wheels that fit.
I’m looking at some injora Range Rover wheels for my trx4 and I’ve been reading that some wheels fit and some do not. The wheels in particular have the retaining ring on the inside of the wheel and the ID of the back side of the wheel is 39mm. Can any of you tr4 gurus on here say one way or another if these wheels will fit? If this works, these are the wheels https://www.google.ca/search?q=injor...dzHVCk6vw1EuxM |
01-23-2022, 07:36 PM | #2 |
| Re: Wheels that fit.
Although I don't have those wheels, I thought I'd try to put up some helpful info... Here's a better link to those wheels: https://www.injora.com/products/4pcs...-10-rc-crawler and the pic with dimensions: Last edited by durok; 01-23-2022 at 07:38 PM. |
01-23-2022, 07:37 PM | #3 | |
Rock Crawler Join Date: Jan 2022 Location: st louis
| Re: Wheels that fit. Quote:
Sent from my SM-N975U using Tapatalk | |
01-23-2022, 07:54 PM | #4 |
Thanks Durok, I hope that helps. I’m new to the trx platform and I’ve just begun building my kit. I could measure from the axle shaft to the top of the portal box once I’ve built but but I thought I’d tap into the knowledge in here as well.
01-23-2022, 07:55 PM | #5 |
Quarry Creeper Join Date: Jan 2021 Location: in the Canyon
Basically, if the wheel uses the inner ring style pictured above, it's not going to fit over portals. Source: I've tried it. |
01-23-2022, 08:34 PM | #6 |
If you want Land Rover / Range Rover style wheels, there is a more modern design that would work, they have the very large inner rim design: https://www.injora.com/products/4pcs...39450997063728 |
01-23-2022, 09:35 PM | #7 |
BTW - I knew we had a very good thread on this type of issue - so I went on a quick search and found it: TRX4 wheel fitment info |
01-24-2022, 04:49 AM | #8 |
Thanks Durok. I took a read through the trx4 wheel fitment tread. I think if I want the style of wheel I’m after, I’d have to spend mucho dollars and get cchand ones.
01-24-2022, 06:39 AM | #9 | |
Quarry Creeper Join Date: Nov 2020 Location: Greece
I have these wheels and can confirm that they fit perfectly. | |
Wheels that fit. - Similar Threads | ||||
HELP!! Tires won't fit on wheels | AMPnGeorgia | Newbie General | 5 | 06-08-2014 01:00 PM |
What Wheels Fit? | The Jackalope | Redcat Crawlers | 1 | 03-11-2011 09:39 AM |
What wheels fit. | Fozzy Down Under | Newbie General | 5 | 04-08-2006 01:21 AM |
Will these wheels fit? | badtodabone | Tamiya TLT Crawlers | 1 | 06-18-2005 08:57 PM |
will normal wheels fit? | badtodabone | Tires and Wheels | 8 | 03-02-2005 03:20 PM |
