Programmable Sub Micro Servos Has anybody tried a set of programmable sub micro servos, such as the Futaba S3270sVI for the diff locks/transmission? Aside from cost and availability, does anyone see any potential problems? Thank you. MC |
Re: Programmable Sub Micro Servos I have not but I do know the sub micro servos can have different dimensions and that could potentially cause issues. So are you just looking to be able to set end points on a TRX4? Have you considered a HeyOK end point adjuster: https://www.heyokperformance.com/End..._18344974.aspx I have one that I think can control 2 or 3 servos but I only see the single version on the site. Al is super helpful and if you wanted to contact him I would wager he could make one for how ever many servos you need to control. |
Re: Programmable Sub Micro Servos HEF, I have seen HeyOk’s endpoint adjusters, but don’t care to add all of the additional wiring. And yes, I am just looking for an alternative setup for the diffs/trans. I am currently using Pro Modeler sub micro servos with the stock servo savers. The combo works pretty much flawlessly, but I’m always looking for something that is even more reliable. Thank you. Sincerely, MC |
