05-10-2015, 09:27 AM | #141 |
RCC Addict Join Date: May 2013 Location: York, PA
| Re: Mini Super
I've been busy all weekend working on the deck, so not much progress. After doing some thinking following my shake down run, I realized the rear axle didn't really need to be narrower than the front, since it steers. So I adjusted it to match the front. Go as wide as you can for stability, I figure. Also, the superclass section has been my main reading lately, trying to learn about this style of rig. I just couldn't get past the fact that the rigs there look like "all tires", with a little bit of chassis hidden between. I had a set of BC's that I got on a package deal that have been sitting around forever. So I took a little time to narrow them and fit them on the rig. Due to the rework I did on the front links earlier, there's no loss of steering with this much taller tire. Now it's looking "Super", or at least in my opinion....lol |
05-10-2015, 09:41 AM | #142 | |
RCC Addict Join Date: Jan 2009 Location: Bend
| Re: Mini Super Quote: Honestly, I envy you guys with tire modding skills. Tires and scissors have never been a good combo for me. | |
05-10-2015, 09:42 AM | #143 |
| Re: Mini Super
Dayum! That looks Super! Tho, I can't believe you've been holding out on the BC's! ;) How tall did they turn out? A touch over 5"? |
05-10-2015, 09:54 AM | #144 |
Rock Crawler Join Date: Feb 2013 Location: york
| Re: Mini Super
That looks sick Merc now you need bigger wheels and low pro tires
05-10-2015, 12:54 PM | #145 | ||
I'd say that's about right. Just a smidge over 5". I didn't think they were going to fit after using my sportsman tires for mockup way back in the beginning. Narrowed, and on narrow rims seems to make the difference. They may not be the final version of shoes on this rig, I'm just using them for testing since I really don't have a knowledge base to pull from. They may be too tall for the narrow track width, or to narrow themselves to prevent sidewall deflection when sidehilling or steering uphill. Worth a try, though. Quote:
I said that way back in the beginning before the class was even invented. There was much discussion of limiting the rims, or tires, or both. I think a 3.2 tire with low profile rubber would be the ultimate. Less tire deflection, less weight, more room for weights way down low and at the corners, etc. I'm still in the mode of trying to use what I have since it's all very experimental. These were here, and found themselves under the knife, for better or worse. | ||
05-10-2015, 01:58 PM | #146 |
| Re: Mini Super
I can't stop looking at these tires! awesome shave job on the outer lugs! (In the back of my head) hoping you don't do, the every other row pin cut... Do something fancy! ;) 3.2 wheels would look Sick, w/ those tires too..... |
05-10-2015, 06:37 PM | #147 | |
If you've got a pattern that's "interesting", let me know. I plan to run them as is, first. You always say "change one thing at a time", so I'm just going to try them out and see if they're even viable. Then I'll start getting creative. I've got a decent amount of time getting to this point with the set. No need to go overboard, just yet. Obvious question would be your foam recommendation. My guess would be narrow cut CI foams, soft front, med rear; but this is a whole different animal than I'm used to. | |
05-10-2015, 07:42 PM | #148 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
| Re: Mini Super
Yup, 'super' job on those BC's. I really like where you've taken this build.
05-10-2015, 10:01 PM | #149 | |
I agree, one thing at a time.. It's amazing what cutting some pins out of them, will do for grip. Just running your finger over them, as is, then cutting a row of pins and running your finger over them again. You can instantly feel the difference in bite.. But you can get to that.. Foams.. Will change depending on the rigs rtr weight, if your leaving the sidewall's as is or shaving the rest, amount of use/break in, pin cut, and amount of wear. I'll use 2 different foam setups per life of the front tires. 1x when new, then change them half way thru there life span. The rears, they will stay the same, most of the times. I have foams here that I'll never use, so many foams...... Some old school 5/5.25 closed cell, narrow, inners and outers to go with them. They came narrow, so no need to cut. Maybe a trim on the width of the outers. I stepped up to 5.5 CC inner and 5.25 outer(for when new). Same 5.25 inner diameter(between the ribs), but a touch wider and a little better sidewall support, for the full size BC's. EDIT: Incase you wondered how I got so close on the tire size or selection of foams.. ;) Last edited by winnerone23; 05-10-2015 at 10:47 PM. | |
05-11-2015, 11:06 AM | #150 |
| Re: Mini Super
This build gives me an...... Rock Porn!! |
05-11-2015, 11:11 AM | #151 |
| Re: Mini Super
^E-rock-tion..?
05-11-2015, 11:14 AM | #152 |
| Re: Mini Super |
05-11-2015, 06:35 PM | #153 |
| Re: Mini Super
As always, RCBros shipped out my knuckle weights ridiculously fast. I think the shop is in the middle of a move right now, and they were still here in 4 days. Very nice. My usual practice is to tap them to 3mm upon arrival; but the tap just spun free in these weights. I don't know if they've started going 3mm; but I'm pleasantly surprised. The weights I used for the shakedown run were stolen off my sportsman rig. It's time this rig had it's own weights. I really have no idea where I'm at on weight, or bias. I got a handful of goodies and just mocked them up for right now. Got one extra half weight on here. May be useful, maybe not. Honestly, I'm waiting for the plastic gears to show. They'll be in the rear, for sure. Maybe both cases. Then I can really establish what this rig needs for knuckle weights. Last edited by MRCrackhead; 05-11-2015 at 06:37 PM. |
05-11-2015, 06:45 PM | #154 |
RCC Addict Join Date: May 2012 Location: Folsom
| Re: Mini Super
Here's a pic of my 6ex battery compartment. Hope this helps. It approx. 1.5 in deep.
05-11-2015, 08:14 PM | #155 |
| Re: Mini Super
Sounds like you are about ready to tune this rig!
05-11-2015, 11:24 PM | #156 |
| Re: Mini Super
As far as I know, RCBros weights have always been tapped 3mm. At least for as long as I've been buying them. |
05-12-2015, 05:19 AM | #157 | |
3mm wouldn't thread in the first couple sets I bought, 4-40 spun in smooth. Just figured that's what they were. It took 'some' effort to run the tap into those, these spun free on the tap. Last edited by MRCrackhead; 05-12-2015 at 05:25 AM. | |
05-12-2015, 07:08 AM | #158 |
| Re: Mini Super |
05-12-2015, 07:41 AM | #159 |
| Re: Mini Super
Yeah its super easy. It handles 3s no problem too. Only bummer is if you leave the radio on. It pretty much drains one cell beyond recovery.
05-12-2015, 12:22 PM | #160 |
| Re: Mini Super |
Mini Super - Similar Threads | ||||
Super mini class | Erik D_lux | WRCCA Information | 180 | 06-18-2018 04:11 PM |
Mini/Micro/Super? | MikeChino | Losi Micro-Rock Crawler | 6 | 10-29-2013 08:24 AM |
my mini super | emaxxjeremy | Losi Mini-Rock Crawler | 7 | 11-09-2008 11:36 PM |
