05-14-2015, 04:33 PM | #21 |
Rock Crawler Join Date: Feb 2013 Location: york
| Re: Dlux Super Mini
what's the overall track width with projected to be with these axles?
05-15-2015, 01:12 AM | #22 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
| Re: Dlux Super Mini |
05-15-2015, 07:29 AM | #23 | |||
| Re: Dlux Super Mini Quote:
Just incase anybody else is building and wants ideas, there is quite a bit that you can probably see on the short side that can simply be cut down. On the long side, I considered inserting a brass insert into the link/shock mount so I could eliminate the nut and move that over or, thread into the servo mount. Also, on the long side you could trim the tube flange down, move the servo mount over and attach the servo mount straight to the gear box. Quote:
I will do it, I have to. Quote:
No idea. Just as tight as possible. If my math serves me, I am down about 3/4" now and I can get about .350" per side off with hubs for about another 3/4" so, if I can fit all of those savings, thats 1.5" total off and if I use my current 2.2p tires, that would put me around 8.5", which is where I want to be. I am not counting on it. Just counting on "as good as possible". | |||
05-15-2015, 07:42 AM | #24 |
| Re: Dlux Super Mini
After working on these axles, I really started to take another look at the LCC axles. They are close to the perfect width approx 6" (same as what I just made with the "Mini Lites") stock. The motor sits length wise, so youre going to have a much easier time getting around the motor and servo or whatever. My first thought on them was to not use them as I thought I would use a 4.25" tire. The problem is that the tires are not big enough to clear the servo when upside down so you would always take rollovers. I think with a 5.5" tire, this is not an issue though. Sure, the LCC axles have a lot of shortcomings, some can be worked through, some not but if somebody wanted to get into this class on the super cheap, I think LCC axles with the MOA kit would be the way to go. |
05-16-2015, 11:04 PM | #25 |
RCC Addict Join Date: Jan 2009 Location: Bend
| Re: Dlux Super Mini
I still find myself digging up the threads from your last worm geared MRC from time to time. I can't even begin to imagine what you'll build without rules or regulations other than gate width. Can't wait to see what you come up with. Not sure if you're keeping the LCC outers or not on this build, but I still have a pair of your LCC knuckle weights collecting dust. I remember you saying I had bought one of the last pairs you had. If you want them for this build shoot me a PM. |
05-17-2015, 12:15 AM | #26 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Dlux Super Mini Quote: |
05-17-2015, 10:54 PM | #27 |
| Re: Dlux Super Mini
I have a set of losi axles sitting around. Seriously just today I was thinking about making a mini super with them.. But they lacked the huge advantage you guys have, MOA. I think if I could find an MOA kit for them I would be all in for this new class.. Or maybe I'll just buy some of those mini-lite axles |
05-18-2015, 07:02 AM | #28 |
| Re: Dlux Super Mini
Hmmm... I lean on that sweet little post about the LCC axles.. As I happen to have (you know) some Eritex moa adapter's... Now just to figure out how to get the tangs to work on uni's, in the LCC locker's.. :/ I might just have to ship them off for some tangs.. ;) Those mini-lite's are Sick! |
05-18-2015, 08:04 AM | #29 | ||||
I think I may have confused you. I am not switching out to LCC axles. I just happen to think about them after finishing the Mini Lites, thinking how they are about the same width and also thinking about how screwed I am for fitment while the LCC axles would afford so much more room. Oh, and the ground clearance under the axles on an LCC cant be beat! Quote:
FYI, the LCC tang is square, the flats measure 4.5mm. Really though, if you wanted in on the cheap, you could run a stock LCC axle with MOA setup or even a shafty. | ||||
05-18-2015, 08:25 AM | #30 |
05-18-2015, 08:37 AM | #31 |
| Re: Dlux Super Mini
This build is going to lighten my bank account! Awesome work Erik! EDIT: Yeah, I know about the darn square "tangs".. But I think XR steering is in order.. If I'm going to do it, I atleast want my steering, that I have parts for.. |
05-18-2015, 09:31 AM | #32 |
| Re: Dlux Super Mini
Yeah, who can deal with 50* of steering anymore Oh, and besides, the LCC CVD pins and hex pins are horrible. |
05-19-2015, 09:22 AM | #33 |
05-19-2015, 09:24 AM | #34 |
05-19-2015, 09:26 AM | #35 |
| Re: Dlux Super Mini Last edited by Erik D_lux; 05-19-2015 at 09:35 AM. |
05-19-2015, 11:25 AM | #36 |
RCC Addict Join Date: May 2012 Location: Folsom
| Re: Dlux Super Mini
Oreo link mount!
05-19-2015, 01:32 PM | #37 |
| Re: Dlux Super Mini
I know! I might have to change it because it makes me hungry!
05-19-2015, 08:34 PM | #38 |
Rock Crawler Join Date: May 2012 Location: Australia
| Re: Dlux Super Mini
When you get a chance, can you post a pic of it next to your 2.2. Just want to gauge how big it is.
05-20-2015, 06:32 AM | #39 |
| Re: Dlux Super Mini
Yeah, I will get one ASAP. Other than the chassis, its not that different. Pretty much my 2.2P car with a different chassis and rear steer.
05-21-2015, 09:38 AM | #40 |
Dlux Super Mini - Similar Threads | ||||
DLUX super build | Erik D_lux | Superclass Crawlers | 578 | 07-20-2016 09:13 AM |
Dlux Super and 2.2 super lite axles in Wendover, NV | Erik D_lux | Videos! | 0 | 07-08-2013 10:08 AM |
Dlux mini build | Erik D_lux | Losi Mini-Rock Crawler | 92 | 09-22-2011 05:28 PM |
